Ana içeriğe geç
Canon EOS 60D Rear LCD Screen Replacement
Neye ihtiyacın var
  1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen Dissasembly: adım 1, 1 resimden 1.
    • Take the LCD out of its place to expose the Phillips #PH00 screws.
    • Remove the two 2.5 mm Phillips #PH00 black screws on both sides of the LCD screen.
    • Next remove the two 3 mm Phillips #PH00 black screws near both sides of the base where the screen swivels.
  2. Canon EOS 60D Rear LCD Screen Replacement: adım 2, 1 resimden 1.
    • Using a plastic opening tool, carefully pry off the back cover of the LCD.
  3. Canon EOS 60D Rear LCD Screen Replacement: adım 3, 2 resimden 1. Canon EOS 60D Rear LCD Screen Replacement: adım 3, 2 resimden 2.
    • Remove the 3 mm Phillips #PH00 silver screw on the side of the screen.
    • Turn the screen to remove the second 3 mm Phillips #PH00 silver screw.
  4. Canon EOS 60D Rear LCD Screen Replacement: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Using the tweezers, carefully disconnect the rear connector by pulling it away from the screen.
  5. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: adım 5, 2 resimden 1. Canon EOS 60D Rear LCD Screen Replacement, Rear LCD Screen: adım 5, 2 resimden 2.
    • Remove the two 2.5 mm Phillips #PH00 silver screws using the PH00 screwdriver.
    • Using the plastic Spudger opening tool, carefully lift up on the medal tabs next to where the screws were located.
  6. Canon EOS 60D Rear LCD Screen Replacement: adım 6, 1 resimden 1.
    • Finally, remove the LCD screen by grabbing the clear plastic tab and lifting it carefully.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Alejandro Cabrera
416 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-6, Wollert Fall 2015 USF Tampa, Team 16-6, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G6
3 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 19
Son 30 gün: 77
Her zaman: 7,808
