Ana içeriğe geç
Canon EOS 60D Rubber grips Replacement
Neye ihtiyacın var
  1. Canon EOS 60D Rubber grips Replacement, Rubber grips: adım 1, 1 resimden 1.
    • Use a thin piece of plastic, spudger, or fingernail (if you have them) to lift up the edge of the grip, and pull up slowly.
    • Repeat for the other two grips
    • The large one on the battery-side is the easiest to start with. This is required to remove the front & back panels
    • The small one on the back is a bit difficult to get started, but not really difficult to remove.
    • The one on the AV panel will be easier if you open up the AV port cover.
    • Remove the adhesive like you would rubber cement, just rub your finger against it, it will come off.
    • Optionally throw the balled up adhesive at people pretending its a booger :)
Sonuç
Double stick tape, or rubber cement (placed carefully) should work well. Studio-mount (sheets of double-stick tape) cut to size should also work.
10 farklı kişi bu kılavuzu tamamladı.
Eric D
1.284 İtibar
5 adet Kılavuz yazıldı
Bir Yorum
Where can we get replacement grips?
Luke Lin - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 8
Son 30 gün: 46
Her zaman: 11,937
