Ana içeriğe geç
Canon EOS 6D Analog Screen Replacement
Neye ihtiyacın var
    1. Canon EOS 6D Analog Screen Replacement, Rear Body Panel: adım 1, 1 resimden 1.
      • Remove the viewfinder cover by pinching the sides and sliding it upward.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 6D Analog Screen Replacement: adım 2, 1 resimden 1.
      • Open the battery door on the bottom of the camera.
      • Use your thumb to slide the small black tab on the inside of the battery door up and pull the door off the camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 6D Analog Screen Replacement: adım 3, 1 resimden 1.
      • Slide your fingernail or the flat end of the spudger underneath the rubber covering and gently peel it off all sides of the camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 6D Analog Screen Replacement: adım 4, 1 resimden 1.
      • Open the covers to the HDMI/AV/MIC ports on the side of the camera by gently pulling outward on the bottom of the covers.
      • Rotate the covers to the side so that you can see the connection ports inside.
      • Remove the following screws:
      • Two silver 5mm Phillips #00
      • One black 6mm Phillips #00
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 6D Analog Screen Replacement: adım 5, 1 resimden 1.
      • Remove the cover to the HDMI/AV/MIC ports by gently lifting the tab on the bottom edge of the camera.
      FixBot'a Sor
      Yorum Ekle
    6. Canon EOS 6D Analog Screen Replacement: adım 6, 1 resimden 1.
      • Rotate your camera so the bottom side is facing you.
      • One 6mm Phillips #00
      • Two 3mm Phillips #00
      FixBot'a Sor
      Yorum Ekle
    7. Canon EOS 6D Analog Screen Replacement: adım 7, 1 resimden 1.
      • Rotate your camera so the back is facing you.
      • Three silver 5mm Phillips #00
      • Two black 6mm Phillips #00
      • One black 4mm Phillips #00
      FixBot'a Sor
      Yorum Ekle
    8. Canon EOS 6D Analog Screen Replacement: adım 8, 2 resimden 1. Canon EOS 6D Analog Screen Replacement: adım 8, 2 resimden 2.
      • A black ribbon wire connects the rear panel to the inside of the camera. Breaking this wire would make your rear screen and buttons non-functional.
      • Carefully use your fingers to tilt the back panel downward to about a 90 degree angle.
      • Use the flat end of the spudger to gently pry off the ribbon wire from the inside of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 6D Analog Screen Replacement, Front and Top Body Panels: adım 9, 1 resimden 1.
      • Remove the 8mm Phillips #00 screw from the bottom of the front of the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 6D Analog Screen Replacement: adım 10, 1 resimden 1.
      • Rotate the camera so the side with the SD card slot is facing you.
      • Remove the 4mm Phillips #00 screw from the bottom edge of this side.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 6D Analog Screen Replacement: adım 11, 1 resimden 1.
      • Rotate the camera so the bottom is facing you.
      • Two 8mm Phillips #00
      • One 4mm Phillips #00
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 6D Analog Screen Replacement: adım 12, 1 resimden 1.
      • Remove the bottom panel from the camera by using your fingers to pull outward on the tab inside the battery compartment.
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 6D Analog Screen Replacement: adım 13, 1 resimden 1.
      • Rotate the camera so the front is facing you.
      • Three 5mm Phillips #00
      • Two 6mm Phillips #00
      FixBot'a Sor
      Yorum Ekle
    6. Canon EOS 6D Analog Screen Replacement: adım 14, 1 resimden 1.
      • One 4mm fine-thread Phillips #00
      • Two 4mm coarse-thread Phillips #00
      FixBot'a Sor
      Yorum Ekle
    7. Canon EOS 6D Analog Screen Replacement: adım 15, 1 resimden 1.
      • The red speaker wire is attached to the inside of the front panel. Opening the front panel forcefully may break it.
      • Slowly fold the front panel to the right without pulling it away from the right edge of the camera.
      FixBot'a Sor
      Yorum Ekle
    8. Canon EOS 6D Analog Screen Replacement: adım 16, 1 resimden 1.
      • Remove the 4mm Phillips #00 screw on the inside of the front panel to separate the panel from the speaker wire.
      FixBot'a Sor
      Yorum Ekle
    9. Canon EOS 6D Analog Screen Replacement: adım 17, 1 resimden 1.
      • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the strap hook.
      FixBot'a Sor
      Yorum Ekle
    10. Canon EOS 6D Analog Screen Replacement: adım 18, 1 resimden 1.
      • Remove the 4mm Phillips #00 screw from the inside of the top panel, below the shutter button.
      FixBot'a Sor
      Yorum Ekle
    11. Canon EOS 6D Analog Screen Replacement: adım 19, 1 resimden 1.
      • Rotate the camera so the top is facing you.
      • Remove the 6mm Phillips #00 screw from next to the analog screen.
      FixBot'a Sor
      Yorum Ekle
    12. Canon EOS 6D Analog Screen Replacement: adım 20, 1 resimden 1.
      • Rotate the camera so the back is facing you.
      • Remove the Phillips #00 screw from the viewfinder focus.
      FixBot'a Sor
      Yorum Ekle
    13. Canon EOS 6D Analog Screen Replacement: adım 21, 1 resimden 1.
      Bu adımda kullanılan alet:
      • Carefully detach the two light brown ribbon wires on the top panel:
      • The right ribbon by prying it out with the flat end of the spudger.
      • The left ribbon by using tweezers to gently wiggle it out toward the top.
      FixBot'a Sor
      Yorum Ekle
    14. Canon EOS 6D Analog Screen Replacement: adım 22, 1 resimden 1.
      • A ribbon wire connects the inside of the top panel to the body of the camera.
      • Slowly lift the top panel to about an inch above the body of the camera.
      • Carefully use the flat end of the spudger to detach the ribbon wire from the top of the camera.
      FixBot'a Sor
      Yorum Ekle
    15. Canon EOS 6D Analog Screen Replacement: adım 23, 1 resimden 1.
      • Grip the remaining side panel with your fingers and gently pop it off the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 6D Analog Screen Replacement, Analog Screen: adım 24, 1 resimden 1.
      • Use the pointed end of the spudger to flip up two silver ribbon wire latches on the inside of the top panel.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 6D Analog Screen Replacement: adım 25, 1 resimden 1.
      • Use the pointed end of the spudger to slide out the two light brown ribbon wires.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 6D Analog Screen Replacement: adım 26, 1 resimden 1.
      • Use the pointed end of the spudger to carefully remove the third light brown ribbon wire.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 6D Analog Screen Replacement: adım 27, 1 resimden 1.
      • Remove four 5mm Phillips #00 screws from the inside of the top panel.
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 6D Analog Screen Replacement: adım 28, 2 resimden 1. Canon EOS 6D Analog Screen Replacement: adım 28, 2 resimden 2.
      • Carefully slide the flat end of the spudger underneath the screen and lift it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
Justin Thomas
2.233 İtibar
6 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 11-48, Amido Spring 2014 Cal Poly, Team 11-48, Amido Spring 2014 üyesi
CPSU-AMIDO-S14S11G48
4 Üyeler
20 adet Kılavuz yazıldı
2Kılavuz Yorumları
any way to replace the sd card side panel without having to take the lcd panel off
Nate Kennedy - Yanıt Paylaş
Thank you Justin! Very well done. Fixed the camera for $40 rather than replacing it for 1000+
Matt Ryan - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 17
Son 30 gün: 73
Her zaman: 8,340
