Ana içeriğe geç
Canon EOS 70D Camera Motherboard Replacement
  1. Canon EOS 70D Camera Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
    • Pull cover over to expose the battery.
  2. Canon EOS 70D Camera Motherboard Replacement: adım 2, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 2, 2 resimden 2.
    • Press the white button with your finger to release the battery.
    • Once released, the battery will eject out about two inches
  3. Canon EOS 70D Camera Motherboard Replacement: adım 3, 1 resimden 1.
    • Pull battery out of the camera.
  4. Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: adım 4, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement, LCD Touchscreen: adım 4, 2 resimden 2.
    • Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
    • Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
    • Use a spudger and pry apart the two plastic columns surrounding the screen hinge.
    • The screen will not be removed at this step.
    • Rotate the screen forward 90 degrees and push it back into its housing against the camera.
  5. Canon EOS 70D Camera Motherboard Replacement: adım 5, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 5, 2 resimden 2.
    • Use a spudger to peel rubber matting on left hand side to expose camera backplate mounting screws.
    • Remove three 4 mm Phillip #000 head screws that mount the backplate to the left side of camera.
  6. Canon EOS 70D Camera Motherboard Replacement: adım 6, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 6, 2 resimden 2.
    • Use tweezers to pry rubber matting on right hand side to expose backplate mounting screws.
    • Remove four 4 mm Phillips #000 head screws that mount the backplate to the right side of camera.
  7. Canon EOS 70D Camera Motherboard Replacement: adım 7, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 7, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement: adım 7, 3 resimden 3.
    • Turn camera upside down. Remove five 5 mm Phillips #000 head screws securing the backplate to the bottom of the camera.
    • Grab the backplate and gently pull away from camera.
    • The backplate will still be attached by the wires running to the LCD touchscreen.
    • The screen will still be attached to the camera and won't be removed until step 10.
  8. Canon EOS 70D Camera Motherboard Replacement: adım 8, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 8, 2 resimden 2.
    • Carefully pry open backplate from camera to expose LCD connector (white wire). LCD connector is attached with a metal bar to the motherboard.
    • Use tweezers to gently pry metal bar connector from camera motherboard.
  9. Canon EOS 70D Camera Motherboard Replacement: adım 9, 2 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 9, 2 resimden 2.
    • Remove two 4 mm Phillips #000 head screws that mount the LCD touchscreen to the hinge on the camera.
  10. Canon EOS 70D Camera Motherboard Replacement: adım 10, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 10, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement: adım 10, 3 resimden 3.
    • Grip the screen with your hand and gently pull white connecting wire through hole in backplate.
    • Once the connector reaches the hole, twist the connector and pull completely through hole.
    • You must twist the connector in order to fit through hole.
  11. Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: adım 11, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: adım 11, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement, Camera Motherboard: adım 11, 3 resimden 3.
    • Use spudger to lift edge of black heat tape.
    • Slowly peel back black heat tape.
  12. Canon EOS 70D Camera Motherboard Replacement: adım 12, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 12, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement: adım 12, 3 resimden 3.
    • Very carefully, use spudger to remove nine orangish ribbon cables.
    • Using tweezers remove the two wire cables shown.
    • Slowly remove ribbon cables because they can tear very easily.
  13. Canon EOS 70D Camera Motherboard Replacement: adım 13, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 13, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement: adım 13, 3 resimden 3.
    • Remove seven 5 mm Phillips #000 head screws around motherboard.
    • Once the five screws are removed, remove the metal chip covered by hand.
    • This will leave the mother board exposed, attached by two cable wires underneath.
  14. Canon EOS 70D Camera Motherboard Replacement: adım 14, 3 resimden 1. Canon EOS 70D Camera Motherboard Replacement: adım 14, 3 resimden 2. Canon EOS 70D Camera Motherboard Replacement: adım 14, 3 resimden 3.
    • Slowly lift motherboard to expose the two cable wires underneath.
    • Using tweezers, unattach the two wire cables holding the motherboard in.
  15. Canon EOS 70D Camera Motherboard Replacement: adım 15, 1 resimden 1.
    • Carefully remove motherboard.
Sonuç
12 farklı kişi bu kılavuzu tamamladı.
Tyler Baker
343 İtibar
1 Kılavuz yazıldı
3 Comments
Great write up and illustrations. I'm in the process of repairing a 70D and this will be a great help.
Thank you and keep up the good work!
marcuscleveland85 - Yanıt
Hi, do you know if after replacing the main board it is necessary to configure the camera with some software ? (I heard of spt software)
Stephen Lay -
Hi Tyler my Canon Camera eos 70D isn’t working anymore is it possible to replace the motherboard?
Charlie Laguna - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 8
Son 7 gün: 39
Son 30 gün: 213
Her zaman: 13,572
