Ana içeriğe geç
Canon EOS 70D EFS 18-135mm Lens Main Board Replacement
  1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: adım 1, 3 resimden 1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: adım 1, 3 resimden 2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement, EFS 18-135mm Lens Main Board: adım 1, 3 resimden 3.
    • First, detach the lens by pressing and holding the release button highlighted in the picture.
    • Next, grab the lens and rotate it counter-clockwise when looking at the camera.
    • Finally, when the camera stops rotating, pull the lens away from the camera.
  2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 2, 2 resimden 1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 2, 2 resimden 2.
    • Remove the four 5.5-mm Phillips #000 screws for the lens mount ring (silver ring).
    • Remove the two 4-mm Phillips #000 screws mounting the main board connector.
    • This guide involves removing a lot of very small screws so be sure to have a magnet board to keep track of them.
  3. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 3, 2 resimden 1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 3, 2 resimden 2.
    • Using a spudger, pull the connector loose from the barrel switch ring assembly.
    • Set barrel switch ring assembly to the side.
  4. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 4, 2 resimden 1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 4, 2 resimden 2.
    • Using a spudger, pull the five connectors out of their housing.
    • Use very gentle pressure when pulling connectors out of the lens main board, as they tend to break easily.
  5. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 5, 3 resimden 1. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 5, 3 resimden 2. Canon EOS 70D EFS 18-135mm Lens Main Board Replacement: adım 5, 3 resimden 3.
    • Remove the two 4-mm Phillips #000 main board mounting screws.
    • Remove the main board from the lens with your hand.
    • The main board is now successfully removed from the lens.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Paul
762 İtibar
3 adet Kılavuz yazıldı
0 Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 9
Son 30 gün: 38
Her zaman: 1,961
