Ana içeriğe geç
Canon EOS 70D LCD Touchscreen Replacement
Neye ihtiyacın var
    1. Canon EOS 70D LCD Touchscreen Replacement, Battery: adım 1, 1 resimden 1.
      • Hold the camera with the lens pointing down. Press the highlighted button with your finger to release the cover.
      • Pull cover over to expose the battery.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 70D LCD Touchscreen Replacement: adım 2, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 2, 2 resimden 2.
      • Press the white button with your finger to release the battery.
      • Once released, the battery will eject out about two inches
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 70D LCD Touchscreen Replacement: adım 3, 1 resimden 1.
      • Pull battery out of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS 70D LCD Touchscreen Replacement, LCD Touchscreen: adım 4, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement, LCD Touchscreen: adım 4, 2 resimden 2.
      • Pull Touchscreen out and rotate 90 degrees. Remove the four 3 mm Phillips #000 head screws that are now exposed at the hinge.
      • Remove the two 5 mm Phillips #000 head screws that near the viewfinder.
      • Use a spudger and pry apart the two plastic hinge-covers surrounding the screen hinge.
      • The screen and hinge columns will not be removed at this step.
      • Rotate the screen forward 90 degrees and push it back into its housing against the camera.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS 70D LCD Touchscreen Replacement: adım 5, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 5, 2 resimden 2.
      • Use a spudger to peel rubber matting on left hand side to expose camera backplate mounting screws.
      • Remove three 4 mm Phillip #000 head screws that mount the backplate to the left side of camera.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS 70D LCD Touchscreen Replacement: adım 6, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 6, 2 resimden 2.
      Bu adımda kullanılan alet:
      • Use tweezers to pry rubber matting on right hand side to expose backplate mounting screws.
      • Remove four 4 mm Phillips #000 head screws that mount the backplate to the right side of camera.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS 70D LCD Touchscreen Replacement: adım 7, 3 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 7, 3 resimden 2. Canon EOS 70D LCD Touchscreen Replacement: adım 7, 3 resimden 3.
      • Turn camera upside down. Remove five 5 mm Phillips #000 head screws securing the backplate to the bottom of the camera.
      • Grab the backplate and gently pull away from camera.
      • The backplate will still be attached by the wires running to the LCD touchscreen.
      • The screen will still be attached to the camera and won't be removed until step 10.
      FixBot'a Sor
      Yorum Ekle
    5. Canon EOS 70D LCD Touchscreen Replacement: adım 8, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 8, 2 resimden 2.
      • Carefully pry open backplate from camera to expose LCD connector (white wire). LCD connector is attached with a metal bar to the motherboard.
      • Use tweezers to gently pry metal bar connector from camera motherboard.
      FixBot'a Sor
      Yorum Ekle
    6. Canon EOS 70D LCD Touchscreen Replacement: adım 9, 2 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 9, 2 resimden 2.
      • Remove two 4 mm Phillips #000 head screws that mount the LCD touchscreen to the hinge on the camera.
      FixBot'a Sor
      Yorum Ekle
    7. Canon EOS 70D LCD Touchscreen Replacement: adım 10, 3 resimden 1. Canon EOS 70D LCD Touchscreen Replacement: adım 10, 3 resimden 2. Canon EOS 70D LCD Touchscreen Replacement: adım 10, 3 resimden 3.
      • Grip the screen with your hand and gently pull white connecting wire through hole in backplate.
      • Once the connector reaches the hole, twist the connector and pull completely through hole.
      • You must twist the connector in order to fit through hole.
      FixBot'a Sor
      Yorum Ekle
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Paul
987 İtibar
3 adet Kılavuz yazıldı
6Kılavuz Yorumları
Would this also apply to the 80D, given they’re so similar? Also, is it still possible to stick the rubber bits back down so that they are exactly the same as before?
Lloyd Davies (Bluemosh) - Yanıt Paylaş
No, the 80D is completely different
phily_artorius - Yanıt Paylaş
How far is the 80D different? I would love to see a teardown somewhere… ^^
nexus - Yanıt Paylaş
Where can I purchase the LCD screen assembly?
Fred Noce - Yanıt Paylaş
I know this post is over two years old but I purchased mine from Aliexpress
Mark - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 18
Son 30 gün: 89
Her zaman: 8,241
