Ana içeriğe geç
Canon EOS A2 Front Cover Replacement
Neye ihtiyacın var
  1. Canon EOS A2 Front Cover Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery door/camera grip on the left side of the camera and lift the rotating removal tab.
  2. Canon EOS A2 Front Cover Replacement: adım 2, 1 resimden 1.
    • Twist the tab clockwise to unlock the door, then pull outward from the camera to remove it.
  3. Canon EOS A2 Front Cover Replacement: adım 3, 1 resimden 1.
    • Remove the battery from inside the battery housing and set the cover aside.
  4. Canon EOS A2 Front Cover Replacement, Front Cover: adım 4, 1 resimden 1.
    • Remove the two 6.4mm screws above the lens aperture using a phillips #00 screw driver.
  5. Canon EOS A2 Front Cover Replacement: adım 5, 1 resimden 1.
    • Remove the 6.4mm screw from the inside of the flash bezel.
    • If the flash is locked down, insert the battery, then with the help of a pencil turn the rotary (CW or CCW) switch until the "125" is displayed in the LCD. Press the Flash symbol button. You should hear the latch from the flash, then you can manually lift the flash. If OK, then remove the battery from the camera
  6. Canon EOS A2 Front Cover Replacement: adım 6, 1 resimden 1.
    • Flip the camera upside down and remove the 5.4mm screw below the lens bezel on the front of the camera.
  7. Canon EOS A2 Front Cover Replacement: adım 7, 1 resimden 1.
    • Remove the 5.6mm screws behind the battery cover.
  8. Canon EOS A2 Front Cover Replacement: adım 8, 1 resimden 1.
    • Remove two 6.4mm screws on the latch mechanism on the right side of the camera.
  9. Canon EOS A2 Front Cover Replacement: adım 9, 1 resimden 1.
    • Remove the 6.4mm screw on the top of the inside edge of the battery hole.
  10. Canon EOS A2 Front Cover Replacement: adım 10, 2 resimden 1. Canon EOS A2 Front Cover Replacement: adım 10, 2 resimden 2.
    • Starting at the flash, carefully pull the front cover away from the camera.
Sonuç
Mark
192 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-9, Regan Spring 2011 Cal Poly, Team 8-9, Regan Spring 2011 üyesi
CPSU-REGAN-S11S8G9
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 11
Her zaman: 2,627
