Ana içeriğe geç
Canon EOS Digital Rebel (300D) LCD Screen Replacement
Neye ihtiyacın var
  1. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove the eyecup: adım 1, 1 resimden 1.
    • Remove the eyecup by gently pushing it upwards, so it doesn't block us in the final step of pulling the back casing from the camera's body.
  2. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove bottom screws: adım 2, 1 resimden 1.
    • Remove the three 1/8" philips screws from the bottom of the back casing
  3. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove screws inside CF card compartment: adım 3, 1 resimden 1.
    • Open the CF card compartment by moving it upwards and tilting it away from the camera body.
    • Remove the two 3/16" philips screws besides the CF card slot opening.
  4. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove screws from lateral rubber coating: adım 4, 1 resimden 1.
    • Remove the black screws from the camera's left rubber covering - note it is a 5/16" screw at the top and a 3/16" screw at the bottom.
  5. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove lateral rubber coating: adım 5, 1 resimden 1.
    • Aided by a screwdriver or plastic opening tool, remove the rubber coating from the left side of the camera.
  6. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove hidden screw from the back casing: adım 6, 1 resimden 1.
    • With a pointy tool, remove the soft cap covering the screw.
    • Remove the 3/16" philips screw.
  7. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Detach the back casing from the camera's body: adım 7, 1 resimden 1.
    • Use a plastic opening tool to help detaching the back casing from the camera's body.
  8. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Lift back casing from the camera's body: adım 8, 1 resimden 1.
    • Carefully lift the back casing from the camera's body from left to right.
  9. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove flat cable linking the camera's body to the back casing: adım 9, 3 resimden 1. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove flat cable linking the camera's body to the back casing: adım 9, 3 resimden 2. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove flat cable linking the camera's body to the back casing: adım 9, 3 resimden 3.
    • Locate the connector which holds the flat cable to the main circuit board. Unlock the connector by gently pulling up its black piece from the side the flat cable comes into it.
    • Pull the flat cable from the connector and you'll have completely removed the back casing from the camera.
    • Note I taped each of the screws to their original places on the removed back casing, so I don't loose or mix any of them.
  10. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove screws from LCD chassis: adım 10, 1 resimden 1.
    • Remove the three 1/8" philips screws holding the LCD chassis to the camera's body.
  11. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove power and flat data cable from the main board: adım 11, 3 resimden 1. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove power and flat data cable from the main board: adım 11, 3 resimden 2. Canon EOS Digital Rebel (300D) LCD Screen Replacement, Remove power and flat data cable from the main board: adım 11, 3 resimden 3.
    • Remove the power cable from the main board.
    • Unlock the flat cable connector by pulling out its black edges.
    • Pull out the flat cable from the connector on the main board.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Claudio Felix
893 İtibar
7 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 32
Her zaman: 2,935
