Ana içeriğe geç
Canon EOS Rebel G Back Panel Latch Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel G Back Panel Latch Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Back Panel Latch Replacement: adım 2, 2 resimden 1. Canon EOS Rebel G Back Panel Latch Replacement: adım 2, 2 resimden 2.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Back Panel Latch Replacement: adım 3, 3 resimden 1. Canon EOS Rebel G Back Panel Latch Replacement: adım 3, 3 resimden 2. Canon EOS Rebel G Back Panel Latch Replacement: adım 3, 3 resimden 3.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Back Panel Latch Replacement, Back Panel Latch: adım 4, 1 resimden 1.
    • Using a 00 Phillips screw driver, unscrew the two screws located on the side of the camera.
    • Two 4.3 mm Phillips screws
  5. Canon EOS Rebel G Back Panel Latch Replacement: adım 5, 1 resimden 1.
    • Open the back panel by pushing the locking latch up.
    • Lift the latch cover off of the camera body.
  6. Canon EOS Rebel G Back Panel Latch Replacement: adım 6, 1 resimden 1.
    • Slide the side latch (for the back door) up and then lift straight away from the camera body.
    • Sometimes the latch will detach while pushing it up.
Sonuç
Zach
43 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G9
5 Üyeler
36 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 11
Son 30 gün: 24
Her zaman: 2,552
