Ana içeriğe geç
Canon EOS Rebel G LCD Screen Replacement
Neye ihtiyacın var
    1. Canon EOS Rebel G LCD Screen Replacement, Front Panel: adım 1, 1 resimden 1.
      • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS Rebel G LCD Screen Replacement: adım 2, 2 resimden 1. Canon EOS Rebel G LCD Screen Replacement: adım 2, 2 resimden 2.
      • Using your finger, peel back the textured grip so the components are separated.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS Rebel G LCD Screen Replacement: adım 3, 3 resimden 1. Canon EOS Rebel G LCD Screen Replacement: adım 3, 3 resimden 2. Canon EOS Rebel G LCD Screen Replacement: adım 3, 3 resimden 3.
      • Using the flat end of a spudger, loosen the connection between the front panel and the device.
      • Remove the front panel using your hands.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS Rebel G LCD Screen Replacement, Top Panel: adım 4, 1 resimden 1.
      • Turn Camera over.
      • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS Rebel G LCD Screen Replacement: adım 5, 1 resimden 1.
      • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
      FixBot'a Sor
      Yorum Ekle
    3. Canon EOS Rebel G LCD Screen Replacement: adım 6, 1 resimden 1.
      • Lay the camera on its back.
      • Unsolder the flash connection from the motherboard as noted by the blue circle.
      FixBot'a Sor
      Yorum Ekle
    4. Canon EOS Rebel G LCD Screen Replacement: adım 7, 3 resimden 1. Canon EOS Rebel G LCD Screen Replacement: adım 7, 3 resimden 2. Canon EOS Rebel G LCD Screen Replacement: adım 7, 3 resimden 3.
      • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
      FixBot'a Sor
      Yorum Ekle
    1. Canon EOS Rebel G LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 1. Canon EOS Rebel G LCD Screen Replacement, LCD Screen: adım 8, 2 resimden 2.
      • Pry off the small metal brace holding the LCD screen. (Push forward and slide toward the center)
      FixBot'a Sor
      Yorum Ekle
    2. Canon EOS Rebel G LCD Screen Replacement: adım 9, 1 resimden 1.
      • Lift out the LCD screen.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zach
46 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G9
5 Üyeler
36 adet Kılavuz yazıldı
2Kılavuz Yorumları
Great guide thanks! I found my lcd screen was partially working, the top part of the display was showing incomplete numbers...Cleaning the lcd contacts and reassembling it fixed the issue! No need to replace the screen in my case!
Michelangelo - Yanıt Paylaş
What Kind of glue is suggested to replace the textured grip?
Mark Garcia - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 6
Son 30 gün: 19
Her zaman: 2,027
