Ana içeriğe geç
Canon EOS Rebel G Lens Connector Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel G Lens Connector Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Lens Connector Replacement: adım 2, 2 resimden 1. Canon EOS Rebel G Lens Connector Replacement: adım 2, 2 resimden 2.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Lens Connector Replacement: adım 3, 3 resimden 1. Canon EOS Rebel G Lens Connector Replacement: adım 3, 3 resimden 2. Canon EOS Rebel G Lens Connector Replacement: adım 3, 3 resimden 3.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Lens Connector Replacement, Lens Connector: adım 4, 1 resimden 1.
    • Using a Phillips #00 screwdriver, remove the 5 indicated screws
    • Five 6.2 mm Phillips screws
  5. Canon EOS Rebel G Lens Connector Replacement: adım 5, 1 resimden 1.
    • Using your hands, remove the top black ring.
    • WARNING! The indicated piece is spring loaded. Prepare for it to eject when taking off top ring.
    • Spring located here.
  6. Canon EOS Rebel G Lens Connector Replacement: adım 6, 2 resimden 1. Canon EOS Rebel G Lens Connector Replacement: adım 6, 2 resimden 2.
    • There are two silver metal rings.
    • Remove the top silver metal ring.
  7. Canon EOS Rebel G Lens Connector Replacement: adım 7, 1 resimden 1.
    • Remove the bottom silver ring.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Zach
43 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G9
5 Üyeler
36 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 4
Her zaman: 1,763
