Ana içeriğe geç
Canon EOS Rebel G Strap Anchors Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel G Strap Anchors Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Strap Anchors Replacement: adım 2, 2 resimden 1. Canon EOS Rebel G Strap Anchors Replacement: adım 2, 2 resimden 2.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Strap Anchors Replacement: adım 3, 3 resimden 1. Canon EOS Rebel G Strap Anchors Replacement: adım 3, 3 resimden 2. Canon EOS Rebel G Strap Anchors Replacement: adım 3, 3 resimden 3.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Strap Anchors Replacement, Top Panel: adım 4, 1 resimden 1.
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Strap Anchors Replacement: adım 5, 1 resimden 1.
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Strap Anchors Replacement: adım 6, 1 resimden 1.
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Strap Anchors Replacement: adım 7, 3 resimden 1. Canon EOS Rebel G Strap Anchors Replacement: adım 7, 3 resimden 2. Canon EOS Rebel G Strap Anchors Replacement: adım 7, 3 resimden 3.
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
  8. Canon EOS Rebel G Strap Anchors Replacement, Strap Anchors: adım 8, 1 resimden 1.
    • Unscrew the 6.8 Phillips screw that holds the strap anchor by the LCD.
  9. Canon EOS Rebel G Strap Anchors Replacement: adım 9, 1 resimden 1.
    • Unscrew the screws that hold the remaining strap anchor.
    • Two 4.9 mm Phillips screws
Sonuç
Kyle Reis
52 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G9
5 Üyeler
36 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 1,175
