Ana içeriğe geç
Canon EOS Rebel G Top Panel Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel G Top Panel Replacement, Front Panel: adım 1, 1 resimden 1.
    • Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
  2. Canon EOS Rebel G Top Panel Replacement: adım 2, 2 resimden 1. Canon EOS Rebel G Top Panel Replacement: adım 2, 2 resimden 2.
    • Using your finger, peel back the textured grip so the components are separated.
  3. Canon EOS Rebel G Top Panel Replacement: adım 3, 3 resimden 1. Canon EOS Rebel G Top Panel Replacement: adım 3, 3 resimden 2. Canon EOS Rebel G Top Panel Replacement: adım 3, 3 resimden 3.
    • Using the flat end of a spudger, loosen the connection between the front panel and the device.
    • Remove the front panel using your hands.
  4. Canon EOS Rebel G Top Panel Replacement, Top Panel: adım 4, 1 resimden 1.
    • Turn Camera over.
    • Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
  5. Canon EOS Rebel G Top Panel Replacement: adım 5, 1 resimden 1.
    • Using a #00 Phillips screw driver, unscrew the one 5.7 mm Phillips screw located next to the LCD screen.
  6. Canon EOS Rebel G Top Panel Replacement: adım 6, 1 resimden 1.
    • Lay the camera on its back.
    • Unsolder the flash connection from the motherboard as noted by the blue circle.
  7. Canon EOS Rebel G Top Panel Replacement: adım 7, 3 resimden 1. Canon EOS Rebel G Top Panel Replacement: adım 7, 3 resimden 2. Canon EOS Rebel G Top Panel Replacement: adım 7, 3 resimden 3.
    • Remove the top panel by lifting it from the back, pushing it forward over the camera and letting it rotate down in front of the camera.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Zach
43 İtibar
8 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 14-9, Forte Spring 2012 Cal Poly, Team 14-9, Forte Spring 2012 üyesi
CPSU-FORTE-S12S14G9
5 Üyeler
36 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 1,861
