Giriş
This guide will teach you how to remove the viewfinder from your camera.
Neye ihtiyacın var
Using a #00 Phillips screw driver, remove three 4.4 mm Phillips screws as indicated by the red circles.
Turn Camera over.
Using a #00 Phillips screw driver, unscrew the two 4.9 mm Phillips screws located on either side of the viewfinder.
Unscrew the screws on either side of the viewfinder until the viewfinder can be lifted off
Two 8.5 mm Phillips screws
