Ana içeriğe geç
Canon EOS Rebel T1i Camera Battery Notch Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: adım 1, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement, Battery Notch: adım 1, 2 resimden 2.
    • Locate the side of camera with the HDMI port.
    • Unscrew the 7mm with a #00 Phillips screw driver.
  2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 2, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 2, 2 resimden 2.
    • Use your fingers to gently detach the plastic component from the camera
  3. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 3, 3 resimden 3.
    • Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
  4. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 4, 1 resimden 1.
    • Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
  5. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 5, 2 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 5, 2 resimden 2.
    • Unscrew the top 7mm screw on the right side of the camera.
    • Unscrew the bottom 4 mm screw on the right side of the camera.
  6. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 6, 3 resimden 3.
    • Use the plastic opening tool to pry open the entire back panel.
    • Use your fingers to pull off the back panel.
  7. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 1. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 2. Canon EOS Rebel T1i Camera Battery Notch Replacement: adım 7, 3 resimden 3.
    • Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
    • Use the pliers (or your fingers) to take off the white notch.
    • There is a spring underneath the battery notch. Do not lose this spring or let it fall off.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Jonathan Lin
548 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 3-41, Maness Spring 2014 Cal Poly, Team 3-41, Maness Spring 2014 üyesi
CPSU-MANESS-S14S3G41
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 19
Her zaman: 3,197
