Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Locate the side of camera with the HDMI port.
Unscrew the 7mm with a #00 Phillips screw driver.
Use your fingers to gently detach the plastic component from the camera
Unscrew the bottom three 4mm screws with a #00 Phillips screwdriver.
Unscrew the inner 4mm screw with a #00 Phillips screwdriver.
Unscrew the top 7mm screw on the right side of the camera.
Unscrew the bottom 4 mm screw on the right side of the camera.
Use the plastic opening tool to pry open the entire back panel.
Use your fingers to pull off the back panel.
Now that the panel is off, unscrew the 9mm screw holding the battery notch in.
Use the pliers (or your fingers) to take off the white notch.
4 farklı kişi bu kılavuzu tamamladı.
