Ana içeriğe geç
Canon EOS Rebel T3 Back Cover Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 1. Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 2. Canon EOS Rebel T3 Back Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 3.
    • Pry open the rubber I/F terminal cap with your finger.
    • Remove the two M1.7x4.5mm JIS #000 screws that are underneath the I/F terminal cap.
    • Using a plastic pick, or another thin plastic prying tool, pop off the I/F terminal cover from the camera.
  2. Canon EOS Rebel T3 Back Cover Replacement, Back Cover: adım 2, 2 resimden 1. Canon EOS Rebel T3 Back Cover Replacement, Back Cover: adım 2, 2 resimden 2.
    • On the left side of the camera, remove the following screw:
    • One M1.7x4.5mm JIS #000 screw
    • On the right side, remove the following screws:
    • One M1.7x5.5mm JIS #000 screw
  3. Canon EOS Rebel T3 Back Cover Replacement: adım 3, 2 resimden 1. Canon EOS Rebel T3 Back Cover Replacement: adım 3, 2 resimden 2.
    • Remove the battery door.
    • Open the battery door to about a 35° angle.
    • Pull the battery door straight outwards.
    • Remove the following screws from the bottom of the camera:
    • Two M1.7x4.5mm JIS #000 screws
    • Two M1.7x3.0mm JIS #000 screws
  4. Canon EOS Rebel T3 Back Cover Replacement: adım 4, 3 resimden 1. Canon EOS Rebel T3 Back Cover Replacement: adım 4, 3 resimden 2. Canon EOS Rebel T3 Back Cover Replacement: adım 4, 3 resimden 3.
    • Carefully lift the back cover partially off of the camera.
    • There are two ribbon cables still connecting the back cover to the camera.
    • Disconnect the right most ribbon cables from the main PCB board.
    • Use a plastic spudger to lift up the black locking tab.
    • Pull out the ribbon cable from its connector using a pair of angled tweezers.
    • With this ribbon cable disconnected, you will be able to move the back cover slightly farther away from the camera, giving you more room to remove the remaining ribbon cable.
    • Remove the left ribbon cable using the same two steps as with the other ribbon cable.
Sonuç
Ekli Belgeler
Zephosk
4.744 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 10
Son 30 gün: 33
Her zaman: 120
