Ana içeriğe geç
Canon EOS Rebel T4i LCD Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T4i LCD Replacement, Battery: adım 1, 1 resimden 1.
    • Locate the battery cover at the bottom of the camera.
    • Pull down on the black tab to open the cover.
  2. Canon EOS Rebel T4i LCD Replacement: adım 2, 1 resimden 1.
    • Push the grey tab on the right side of the battery.
    • Remove the battery from the slot.
  3. Canon EOS Rebel T4i LCD Replacement, LCD: adım 3, 3 resimden 1. Canon EOS Rebel T4i LCD Replacement, LCD: adım 3, 3 resimden 2. Canon EOS Rebel T4i LCD Replacement, LCD: adım 3, 3 resimden 3.
    • Remove the six screws on the housing of the LCD.
    • Four 3.1mm Phillips screws on the side with the hinge.
    • Two 2.7mm Phillips screws
  4. Canon EOS Rebel T4i LCD Replacement: adım 4, 1 resimden 1.
    • Remove the plastic back of the LCD.
  5. Canon EOS Rebel T4i LCD Replacement: adım 5, 2 resimden 1. Canon EOS Rebel T4i LCD Replacement: adım 5, 2 resimden 2.
    • Unplug the blue cable attached to the back of the LCD.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Jordan Rabold
774 İtibar
3 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 12-33, Maness Spring 2014 Cal Poly, Team 12-33, Maness Spring 2014 üyesi
CPSU-MANESS-S14S12G33
4 Üyeler
14 adet Kılavuz yazıldı
Bir Yorum
where can I buy a replacement LCD screen for my EOS650D camera in Adelaide. Australia
rdmahony4 - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 20
Her zaman: 5,622
