Ana içeriğe geç
Canon EOS Rebel T5 Back Cover Removal
Neye ihtiyacın var
  1. Canon EOS Rebel T5 Back Cover Removal, Battery: adım 1, 1 resimden 1.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Back Cover Removal: adım 2, 1 resimden 1.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Back Cover Removal, Back Cover: adım 3, 1 resimden 1.
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
  4. Canon EOS Rebel T5 Back Cover Removal: adım 4, 1 resimden 1.
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Back Cover Removal: adım 5, 1 resimden 1.
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm JIS #000 screws.
  6. Canon EOS Rebel T5 Back Cover Removal: adım 6, 1 resimden 1.
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
  7. Canon EOS Rebel T5 Back Cover Removal: adım 7, 3 resimden 1. Canon EOS Rebel T5 Back Cover Removal: adım 7, 3 resimden 2. Canon EOS Rebel T5 Back Cover Removal: adım 7, 3 resimden 3.
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Johnyp
269 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G4
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 3,677
