Ana içeriğe geç
Canon EOS Rebel T5 Motherboard Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T5 Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 Motherboard Replacement: adım 2, 1 resimden 1.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 Motherboard Replacement, Back Cover: adım 3, 1 resimden 1.
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm JIS #000 screw above the rubber USB port cover.
    2 more screws behind rubber cover.
    Michael Gill - Yanıt
  4. Canon EOS Rebel T5 Motherboard Replacement: adım 4, 1 resimden 1.
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  5. Canon EOS Rebel T5 Motherboard Replacement: adım 5, 1 resimden 1.
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm JIS #000 screws.
    There is a 6th screw next to the battery door.
  6. Canon EOS Rebel T5 Motherboard Replacement: adım 6, 1 resimden 1.
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm JIS #000 screws.
    Instructions are forgetting the two screws on either side of the viewfinder…. Viewfinder slides up to reveal two screws.
    Hugh Morand - Yanıt
  7. Canon EOS Rebel T5 Motherboard Replacement: adım 7, 3 resimden 1. Canon EOS Rebel T5 Motherboard Replacement: adım 7, 3 resimden 2. Canon EOS Rebel T5 Motherboard Replacement: adım 7, 3 resimden 3.
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
    Do NOT pry until you’ve removed the eye gasket, and the 2 screws behind this! You will break the camera.
  8. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: adım 8, 2 resimden 1. Canon EOS Rebel T5 Motherboard Replacement, Motherboard: adım 8, 2 resimden 2.
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
    • Take note of this black cable and where it connects to the motherboard. This is a fiber optic cable which is used for the camera flash. It will need to be reconnected after replacing the motherboard.
    • When reconnecting the fiber optic cable, simply push the black cable into the hole in the connector and push it all the way in.
  9. Canon EOS Rebel T5 Motherboard Replacement: adım 9, 1 resimden 1.
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm JIS #000 screws.
  10. Canon EOS Rebel T5 Motherboard Replacement: adım 10, 3 resimden 1. Canon EOS Rebel T5 Motherboard Replacement: adım 10, 3 resimden 2. Canon EOS Rebel T5 Motherboard Replacement: adım 10, 3 resimden 3.
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  11. Canon EOS Rebel T5 Motherboard Replacement: adım 11, 1 resimden 1.
    • Remove the black 5 mm JIS #000 screw, located under the grip.
    they is a cable i think gray in color on the top panel, where does it fit, it seems to come out easily
    Tshepiso Marques Molefe - Yanıt
  12. Canon EOS Rebel T5 Motherboard Replacement: adım 12, 1 resimden 1.
    • Remove the top panel of the device.
  13. Canon EOS Rebel T5 Motherboard Replacement: adım 13, 2 resimden 1. Canon EOS Rebel T5 Motherboard Replacement: adım 13, 2 resimden 2.
    • Remove the front panel of the camera.
  14. Canon EOS Rebel T5 Motherboard Replacement: adım 14, 3 resimden 1. Canon EOS Rebel T5 Motherboard Replacement: adım 14, 3 resimden 2. Canon EOS Rebel T5 Motherboard Replacement: adım 14, 3 resimden 3.
    • Remove the five silver 5mm JIS #000 screws.
    • The motherboard can now be removed.
    Where can I buy a Motherboard for a T7 and what would the cost be?
    Dean Smith - Yanıt
Sonuç
10 farklı kişi bu kılavuzu tamamladı.
Austin Tucker
1.057 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G4
4 Üyeler
16 adet Kılavuz yazıldı
2Kılavuz Yorumları
This guide is amazing, but if you change the mainboard do you have to initialize it by software, like Spt?
Edgar Nunes - Yanıt
New main board from canon .
How to instalize?
Thomas Nguyen - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 34
Her zaman: 4,423
