Ana içeriğe geç
Canon EOS Rebel T5 SD Card Reader Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T5 SD Card Reader Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Reader Replacement: adım 2, 1 resimden 1.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Reader Replacement, SD Card: adım 3, 1 resimden 1.
  4. Canon EOS Rebel T5 SD Card Reader Replacement: adım 4, 1 resimden 1.
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
  5. Canon EOS Rebel T5 SD Card Reader Replacement, Back Panel: adım 5, 1 resimden 1.
    • Turn the camera so that the back is facing to your right.
    • Remove the 5mm Phillips #000 screw above the rubber USB port cover.
  6. Canon EOS Rebel T5 SD Card Reader Replacement: adım 6, 1 resimden 1.
    • Remove the rubber piece.
    • Unscrew the two screws under the rubber cover to completely remove the rubber cover piece.
    • It is held in place by a notched tether, but can be easily manipulated to slide out.
  7. Canon EOS Rebel T5 SD Card Reader Replacement: adım 7, 1 resimden 1.
    • Turn your camera so that the bottom is facing you.
    • Remove the 5mm Phillips #000 screws.
  8. Canon EOS Rebel T5 SD Card Reader Replacement: adım 8, 1 resimden 1.
    • Now turn the camera so that the front is facing towards your right.
    • Remove the two remaining 5mm Phillips #000 screws.
  9. Canon EOS Rebel T5 SD Card Reader Replacement: adım 9, 3 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 9, 3 resimden 2. Canon EOS Rebel T5 SD Card Reader Replacement: adım 9, 3 resimden 3.
    • Now that all of the exterior screws have been removed, grip the camera firmly on both sides.
    • Gently pry the back panel from the main body of the camera.
    • There are two ribbon cables that need to be removed in order for the back panel to come free from the camera body, as indicated.
    • This back panel contains various control components of the camera as well as the LCD screen.
  10. Canon EOS Rebel T5 SD Card Reader Replacement, LCD Screen: adım 10, 2 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement, LCD Screen: adım 10, 2 resimden 2.
    • Remove the four silver 4mm Phillips #000 screws connecting the LCD screen to the back of the camera.
    • Be sure to lift the ribbon cable to remove the remaining hidden black 4mm Phillips #000 screw.
  11. Canon EOS Rebel T5 SD Card Reader Replacement: adım 11, 1 resimden 1.
    • The LCD screen can now be lifted from the right side to be replaced.
  12. Canon EOS Rebel T5 SD Card Reader Replacement, Motherboard: adım 12, 1 resimden 1.
    • Remove all ribbon cables with the plastic spudger.
    • Gently pry up the black plastic tabs to slide out the ribbon cables
  13. Canon EOS Rebel T5 SD Card Reader Replacement: adım 13, 1 resimden 1.
    • Turn your camera so that the top is facing you.
    • Remove the two black 5 mm Phillips #000 screws.
  14. Canon EOS Rebel T5 SD Card Reader Replacement: adım 14, 3 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 14, 3 resimden 2. Canon EOS Rebel T5 SD Card Reader Replacement: adım 14, 3 resimden 3.
    • Turn the grip side toward you.
    • Remove the rubber grip, using the plastic spudger.
  15. Canon EOS Rebel T5 SD Card Reader Replacement: adım 15, 1 resimden 1.
    • Remove the black 5 mm Phillips #000 screw, located under the grip.
  16. Canon EOS Rebel T5 SD Card Reader Replacement: adım 16, 1 resimden 1.
    • Remove the top panel of the device.
  17. Canon EOS Rebel T5 SD Card Reader Replacement: adım 17, 2 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 17, 2 resimden 2.
    • Remove the front panel of the camera.
  18. Canon EOS Rebel T5 SD Card Reader Replacement: adım 18, 3 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 18, 3 resimden 2. Canon EOS Rebel T5 SD Card Reader Replacement: adım 18, 3 resimden 3.
    • Remove the five silver 5mm Phillips #000 screws.
    • The motherboard can now be removed.
  19. Canon EOS Rebel T5 SD Card Reader Replacement, Image Sensor: adım 19, 2 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement, Image Sensor: adım 19, 2 resimden 2.
    • Remove the three silver 3mm Philips #000 screws from the image sensor holder.
    • Remove the image sensor holder.
  20. Canon EOS Rebel T5 SD Card Reader Replacement: adım 20, 3 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 20, 3 resimden 2. Canon EOS Rebel T5 SD Card Reader Replacement: adım 20, 3 resimden 3.
    • Remove the three remaining silver 3mm Philips #000 screws from the image sensor.
    • Be careful not lose the springs underneath the screws on the image sensor
    • Using your fingers, lift the image sensor from the device.
  21. Canon EOS Rebel T5 SD Card Reader Replacement, SD Card Reader: adım 21, 1 resimden 1.
    • Using the plastic spuger, disconnect the wire strips that are attached to the SD card reader.
  22. Canon EOS Rebel T5 SD Card Reader Replacement: adım 22, 1 resimden 1.
    • Remove the three 3nm Phillips #000 screws connecting the SD card reader to the back of the device.
  23. Canon EOS Rebel T5 SD Card Reader Replacement: adım 23, 2 resimden 1. Canon EOS Rebel T5 SD Card Reader Replacement: adım 23, 2 resimden 2.
    • Using your fingers, remove the SD card reader from the back of the device.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Tyler Brown
846 İtibar
2 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G4
4 Üyeler
16 adet Kılavuz yazıldı
5 Yorum
Very comprehensive tutorial but 2 screws forgotten (on both sides of the viewfinder) and the adjustment thumb knob withdrawal before removing the top panel of the device. Good job anyway, tks
igloo - Yanıt
Is there a video of this?
Hubzilla - Yanıt
Removal of the sensor is NOT required to take the SD board out of the camera. The sensor needs to be fitted back to exactly the same height, otherwise you WILL not retain autofocus. Why was there no mention of this during the steps above?
Lee Gartside - Yanıt
Bonjour , ou peut on acheter le lecteur de carte sd , merci , cordialement
d007 Éric d007 - Yanıt
Step 19 and 20 are only for modifiing or replacing the image sensor
And is not recommended because AF doesn't work without further adjustment
Tom Oos Oss - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 29
Son 30 gün: 80
Her zaman: 9,765
