Ana içeriğe geç
Canon EOS Rebel T5 SD Card Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T5 SD Card Replacement, Battery: adım 1, 1 resimden 1.
    • Lay the camera on its back so that the card/battery door is facing you.
    • Using your fingernail, slide the tab on the battery door up to release the battery door latch.
  2. Canon EOS Rebel T5 SD Card Replacement: adım 2, 1 resimden 1.
    • Lift the now free card/battery door to reveal the battery compartment.
    • Push the gray lever to the right side so that the battery can be removed and replaced with a new one.
  3. Canon EOS Rebel T5 SD Card Replacement, SD Card: adım 3, 1 resimden 1.
  4. Canon EOS Rebel T5 SD Card Replacement: adım 4, 1 resimden 1.
    • Open the battery compartment by lifting the card/battery door. You will see a thin SD Card slot below the battery.
    • Push in the old SD card until it clicks to remove it and then push in the new card until it clicks into place.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Austin Tucker
1.057 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-4, Wollert Fall 2015 USF Tampa, Team 16-4, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G4
4 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 3
Son 30 gün: 24
Her zaman: 3,581
