Giriş
The Canon EOS T6i was a camera produced and sold by Canon in 2015. The functionality of the LCD screen is to produce high resolution images of the photos taken by the camera and to adjust any settings within the camera. In any case where your Canon EOS T6i LCD screen is: cracked,damaged,fading or not functional; this guide will show you how to safely disassembly and remove the screen from the camera for replacement.
Parçalar
Hiçbir parça belirtilmedi.
Remove battery and ground your wrist using a grounding strap to prevent damage to device.
The screen is glued into the casing. Remove the screen by carefulyl lifting along the edges of the case until the screen pops out. Place new screen into the existing casing. A small about of glue or adhesive may be necessary if their isn't sufficient adhesive remaining in the case. Repeat steps in reverse to reapply screen.
Bir başkası bu kılavuzu tamamladı.
2 Yorum
Very simple and great guide for. See the Canon T6i Bundle
Thanks for this awesome guide its really useful for me. see the Canon 80D Bundle
