Ana içeriğe geç
Canon EOS Rebel T7i I/F Terminal Cover Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel T7i I/F Terminal Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 1. Canon EOS Rebel T7i I/F Terminal Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 2. Canon EOS Rebel T7i I/F Terminal Cover Replacement, I/F Terminal Cover: adım 1, 3 resimden 3.
    • Before beginning, remove the battery from the camera.
    • Underneath the two I/F terminal caps, remove the following screws:
    • Three M1.7x5.5mm JIS #000 screws
    • Using a plastic opening pick, peel off the front name plate.
    • Underneath where the name plate was, remove the following screw:
    • One M1.7x5.5mm Phillips #000 screw
  2. Canon EOS Rebel T7i I/F Terminal Cover Replacement: adım 2, 2 resimden 1. Canon EOS Rebel T7i I/F Terminal Cover Replacement: adım 2, 2 resimden 2.
    • Using a plastic opening pick, pry up on the right side of the I/F terminal cover.
    • Pull off the I/F terminal cover from the camera.
Sonuç
Ekli Belgeler
Zephosk
4.741 İtibar
29 adet Kılavuz yazıldı
Ekip
LGBTQ Technicians LGBTQ Technicians üyesi
Community
33 Üyeler
68 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 19
Her zaman: 32
