Giriş
This is a necessary procedure for replacing the bottom cover of the Canon EOS Rebel XS 35mm camera. This guide details how to remove the bottom cover and put a a bottom cover back on, whether it's the same one now fixed, or a new one.
Neye ihtiyacın var
Remove 6 screws using a PH000 Screwdriver.
Remove 1 (7mm) screw
Remove 5 (4mm) screws
With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
