Ana içeriğe geç
Canon EOS Rebel XS 35mm Bottom Cover and More Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover: adım 1, 1 resimden 1.
    • Remove 6 screws using a PH000 Screwdriver.
    • Remove 1 (7mm) screw
    • Remove 5 (4mm) screws
  2. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 2, 1 resimden 1.
    • With your fingers, push on the bottom cover with a horizontal force until it clicks and separates.
  3. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • With tweezers - although you can also use your fingers - you may remove these 5 gears (shown with colored squares around them) and place them somewhere else for the time being. They fall out easily while you're working, so this will help you stay organized.
  4. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement, Bottom Cover and More: adım 4, 1 resimden 1.
    • Remove the 5mm silver Phillips #000 screw.
    • Remove three 4mm Phillips #000 screws.
  5. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 5, 1 resimden 1.
    Satın Al
    • Remove the silver plate with tweezers or fingers.
  6. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 6, 1 resimden 1.
    • Be mindful of the spring attached to the plastic piece. Do not lose it.
    • Remove the plastic black part.
  7. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 7, 1 resimden 1.
    • Remove the black gear with tweezers or fingers.
  8. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 8, 1 resimden 1.
    • Remove the gear with tweezers or fingers.
  9. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 9, 1 resimden 1.
    • Remove the part indicated in the picture with tweezers or fingers.
  10. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 10, 1 resimden 1.
  11. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 11, 1 resimden 1.
  12. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 12, 2 resimden 1. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 12, 2 resimden 2.
    • Remove two 3mm Phillips #000 screws.
    • Remove two silver 3.5mm Phillips #000 screws.
  13. Canon EOS Rebel XS 35mm Bottom Cover and More Replacement: adım 13, 1 resimden 1.
    • Remove the second silver plate using tweezers or fingers.
Sonuç
christiansvezia
1.108 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 361
