Ana içeriğe geç
Canon EOS Rebel XS 35mm Lens Mount Parts Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement, Lens Mount Parts: adım 1, 1 resimden 1.
    • Using a PH000 screwdriver bit, remove the 2 black screws circled in the picture, which are both 6 mm in length and 1.25 mm in diameter.
  2. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: adım 2, 1 resimden 1.
    • Using a PH000 screwdriver bit, remove the 5 black screws circled in the picture, which are all 5.5 mm in length and 2 mm in diameter.
  3. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: adım 3, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Simply using your fingers - although you can use something else such as tweezers - remove the first layer of the lens mount. This first layer is black, plastic, has a red dot at the top, and so on.
  4. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: adım 4, 1 resimden 1.
    • Using (preferably) tweezers - although you can also use your fingers - remove the flimsy brass-colored layer of the lens mount.
  5. Canon EOS Rebel XS 35mm Lens Mount Parts Replacement: adım 5, 1 resimden 1.
    • Using (preferably) tweezers - although you can also use your fingers - remove the silver layer of the lens mount.
Sonuç
Reassembly can be a lot harder than disassembly for this part of the camera, which accounts for the large range in estimated time.
christiansvezia
1.108 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 15
Her zaman: 380
