Ana içeriğe geç
Canon EOS Rebel XS 35mm Top Cover Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: adım 1, 2 resimden 1. Canon EOS Rebel XS 35mm Top Cover Replacement, Top Cover: adım 1, 2 resimden 2.
    • Using a PH000 screwdriver bit, remove the three black screws shown in the two pictures that are all 4 mm in length and 1 mm in diameter.
  2. Canon EOS Rebel XS 35mm Top Cover Replacement: adım 2, 1 resimden 1.
    • Using a Phillips #000 screwdriver, remove the two black screws shown in the picture that are both 6 mm in length and 1.25 mm in diameter.
  3. Canon EOS Rebel XS 35mm Top Cover Replacement: adım 3, 1 resimden 1.
    • Pull off the front cover.
  4. Canon EOS Rebel XS 35mm Top Cover Replacement: adım 4, 3 resimden 1. Canon EOS Rebel XS 35mm Top Cover Replacement: adım 4, 3 resimden 2. Canon EOS Rebel XS 35mm Top Cover Replacement: adım 4, 3 resimden 3.
    • Using an opening tool (you can also use your nails, but try not to use something potentially damaging to the camera such as metal), separate the top cover from the rest of the camera!
Sonuç
Bir başkası bu kılavuzu tamamladı.
christiansvezia
1.108 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 5
Her zaman: 291
