Ana içeriğe geç
Giriş
Use this guide to replace the LCD. The LCD tends to fade after about five years.
Parçalar
Hiçbir parça belirtilmedi.
  1. Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
    • Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
  2. On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • On the bottom, remove the 6mm (13/64") screw with the #00 Phillips Screwdriver.
    • Pry up the panel; starting from the front/bottom corner, as indicated.
    • There's a concealed lip, under the opposite edge.
  3. iPhone Pil Tamir Setleri
    Only $29.99
    Buy Now
    Only $29.99
    Buy Now
  4. Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
    • Use tweezers to lift the panel.
  5. Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
    • Once you have detached the back cover, use a pair of tweezers to lightly pull on strap found connecting the back cover to the camera.
  6. Use the tweezers to gently remove the straps (in the teal box).
    • Use the tweezers to gently remove the straps (in the teal box).
    • Use the Phillips Screwdriver to remove the four screws (in the red dots).
    • Use your fingers to remove the silver plate.
  7. Use the Spudger on the edges of the screen.
    • Use the Spudger on the edges of the screen.
    • Once one end is lose, use the tweezers to lift the screen.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Daniel Bussone
1.239 İtibar
11 adet Kılavuz yazıldı
Takım
Cal Poly, Team 3-41, Regan Winter 2011 Cal Poly, Team 3-41, Regan Winter 2011 üyesi
CPSU-REGAN-W11S3G41
2 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 5
Her zaman: 6,840
