Giriş
Use this guide to remove the lens mount ring. This particular Canon SLR has a plastic lens mount ring that can wear faster than the metal lens mount rings on other models.
Neye ihtiyacın var
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove three medium length screws from the bottom of the camera
Remove the five silver screws from the lens mounting ring using a Phillips screwdriver.
3 farklı kişi bu kılavuzu tamamladı.
