Bu kılavuzda güncel değişiklikler var. En son onaylanmamış sürüme geçin.
Giriş
Use this guide to remove the two metal neck strap loops.
Neye ihtiyacın var
Remove the two 3mm (1/8") black screws from the side cover using a #00 Phillips screwdriver.
Remove three medium length screws from the bottom of the camera
Remove the three long black screws from the bottom using a #00 Phillips screwdriver.
Use tweezers to lift the panel.
Remove the two 4.5mm (.18in) long black screws from the camera grip using a #00 Phillips screwdriver.
Remove the following ribbons with the tweezers by gently pulling on them.
Remove the three black screws, near the eye piece, using the Phillips Screwdriver.
Remove the two 5.0mm (.20in) silver screws from the first loop hole using a #00 Phillips screwdriver (Picture Two).
Remove the 6.8mm (.27in) wide head silver screw from the second loop hole using a #00 Phillips screwdriver (Picture Three).
