Ana içeriğe geç
Canon EOS Rebel XSi Front Panel Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel XSi Front Panel Replacement, Back Panel: adım 1, 1 resimden 1.
    • Squeeze the eyepiece between your index finger and thumb and lift up and off.
  2. Canon EOS Rebel XSi Front Panel Replacement: adım 2, 1 resimden 1.
    • Using the PH000 screwdriver head, remove the four 4 mm screws on the bottom of the camera.
  3. Canon EOS Rebel XSi Front Panel Replacement: adım 3, 1 resimden 1.
    • Using the PH000 screwdriver head, remove the two 3mm screws on the right side of the camera (from the LCD screen).
  4. Canon EOS Rebel XSi Front Panel Replacement: adım 4, 1 resimden 1.
    • Remove grip by slowly peeling off.
  5. Canon EOS Rebel XSi Front Panel Replacement: adım 5, 1 resimden 1.
    • Using the PH000 screwdriver, remove the four 4mm screws behind the eyepiece.
  6. Canon EOS Rebel XSi Front Panel Replacement: adım 6, 1 resimden 1.
    • Using the PH000 screwdriver head, remove one 4 mm screw on the left side of the camera (from the LCD screen).
  7. Canon EOS Rebel XSi Front Panel Replacement: adım 7, 1 resimden 1.
    • Remove the side panel by lifting off with fingers.
  8. Canon EOS Rebel XSi Front Panel Replacement: adım 8, 1 resimden 1.
    • Use hands to pry off the back panel.
  9. Canon EOS Rebel XSi Front Panel Replacement, Front Panel: adım 9, 1 resimden 1.
    • Using the PH000 screwdriver head, remove the four 3mm screws on the front
  10. Canon EOS Rebel XSi Front Panel Replacement: adım 10, 1 resimden 1.
    • Remove front grip by gently peeling from the edge towards the center of the camera
  11. Canon EOS Rebel XSi Front Panel Replacement: adım 11, 1 resimden 1.
    • Using the PH000 screwdriver head, unscrew the 3 mm screw that was under the grip
  12. Canon EOS Rebel XSi Front Panel Replacement: adım 12, 1 resimden 1.
    • Using the PH000 screwdriver, remove the 4mm screw at the bottom of the camera
  13. Canon EOS Rebel XSi Front Panel Replacement: adım 13, 3 resimden 1. Canon EOS Rebel XSi Front Panel Replacement: adım 13, 3 resimden 2. Canon EOS Rebel XSi Front Panel Replacement: adım 13, 3 resimden 3.
    Bu adımda kullanılan alet:
    Satın Al
    • Remove the front panel by using tweezers to pry the panel over the metal ring protrusion
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Erik Mork
596 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 22-10, Maness Winter 2017 Cal Poly, Team 22-10, Maness Winter 2017 üyesi
CPSU-MANESS-W17S22G10
4 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 13
Her zaman: 1,203
