Ana içeriğe geç
Canon EOS Rebel XTi Front Casing Replacement
Neye ihtiyacın var
  1. Canon EOS Rebel XTi Front Casing Replacement, Battery: adım 1, 1 resimden 1.
    • Place the camera upside down, and position it to where the back of the camera is visible.
  2. Canon EOS Rebel XTi Front Casing Replacement: adım 2, 1 resimden 1.
    • Pull the orange tab to the right to release the primary battery.
  3. Canon EOS Rebel XTi Front Casing Replacement: adım 3, 1 resimden 1.
    • To remove the secondary battery, reposition the camera to where the display screen is facing upwards.
    • Place your finger inside the empty battery compartment and pull away from the camera on the ridged battery tab.
  4. Canon EOS Rebel XTi Front Casing Replacement, Memory Card: adım 4, 1 resimden 1.
    • Place the camera on its side with the soft touch grip facing up and the top of the camera facing right.
  5. Canon EOS Rebel XTi Front Casing Replacement: adım 5, 1 resimden 1.
    • Slide the memory card door in the direction of the arrow engraved on the camera.
    • Once the door has slid open to its full position, lift up on the door.
  6. Canon EOS Rebel XTi Front Casing Replacement: adım 6, 1 resimden 1.
    • With the door open, push down the small black plunger next to the CF slot. The CF card will disengage from the slot and be ejected far enough that you can grasp it between thumb and forefinger and remove it from the slot.
    • The plunger will stay in its depressed position until a CF card is again inserted in the slot.
  7. Canon EOS Rebel XTi Front Casing Replacement, Back Casing: adım 7, 1 resimden 1.
    • Remove the three black 4 mm JIS #0 screws on the bottom of the camera.
  8. Canon EOS Rebel XTi Front Casing Replacement: adım 8, 2 resimden 1. Canon EOS Rebel XTi Front Casing Replacement: adım 8, 2 resimden 2.
    • Remove the two black 6 mm Phillips screws from the right side of the camera.
  9. Canon EOS Rebel XTi Front Casing Replacement: adım 9, 3 resimden 1. Canon EOS Rebel XTi Front Casing Replacement: adım 9, 3 resimden 2. Canon EOS Rebel XTi Front Casing Replacement: adım 9, 3 resimden 3.
    • Remove the two black 4 mm Phillips screws on each side of the camera under the strap hooks.
  10. Canon EOS Rebel XTi Front Casing Replacement: adım 10, 1 resimden 1.
    • Remove the two black 4 mm Phillips head screws on the side of the camera opposite to the hand grip.
  11. Canon EOS Rebel XTi Front Casing Replacement: adım 11, 1 resimden 1.
    • Remove the three 1 mm Phillips #0 screws located in the memory card slot.
    • Two of these screws are black, and the third is silver.
  12. Canon EOS Rebel XTi Front Casing Replacement: adım 12, 1 resimden 1.
    • Gently pry off the back casing.
    • Before completely removing the back casing, be sure to disconnect the single ribbon cable running from the motherboard to the LCD display.
    • Use a spudger to lift the tab on the ribbon cable's ZIF connector.
    • Gently pull the ribbon cable out of the connector.
  13. Canon EOS Rebel XTi Front Casing Replacement, Front Casing: adım 13, 1 resimden 1.
    • Remove the single silver 3 mm Phillips screw.
  14. Canon EOS Rebel XTi Front Casing Replacement: adım 14, 1 resimden 1.
    • Remove the single 6 mm Phillips screw.
    • Remove the single 4 mm Phillips screw.
    • Remove the single 3 mm Phillips screw on the bottom of the lens.
  15. Canon EOS Rebel XTi Front Casing Replacement: adım 15, 1 resimden 1.
    • Gently pry off the front casing.
    • There are no ribbon cables to remove for this portion of the disassembly.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Nicholas Abate
656 İtibar
5 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 8-6, Eyestone Fall 2015 USF Tampa, Team 8-6, Eyestone Fall 2015 üyesi
USFT-EYESTONE-F15S8G6
3 Üyeler
18 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 9
Son 30 gün: 20
Her zaman: 1,427
