Ana içeriğe geç
Eşyalarını Tamir Et
Onarma Hakkı
Parçalar ve Aletler
Giriş
Hi!
This is certainly a job you can do yourself, and it doesn't break any seal so it's even warranty-safe.
Just make sure you use a screwdriver that fits perfectly! otherwise you'll end up damaging those little screws.
Parçalar
Hiçbir parça belirtilmedi.
  1. undo screw near the letter 'o' from 'open' that's indicated on the bottom left of the camera
    • undo screw near the letter 'o' from 'open' that's indicated on the bottom left of the camera
  2. Undo screw as indicated by the red arrow.
    • Undo screw as indicated by the red arrow.
    • for this, you need to lift the rubber covers over the data connectors
  3. Nintendo Switch Kit'leri
    Oyuna geri dönmek için hızlı bir düzeltme
    Switch Kit'leri Satın Al
  4. now you can simply slide out the carrier for the 'Date & Time Battery'
    • now you can simply slide out the carrier for the 'Date & Time Battery'
  5. now you have access to the battery.
    • now you have access to the battery.
    • The type is CR1616, 3V , lithium type, original brand as supplied by canon is Maxell.
    • Battery goes in with the +positive side down (as pictured)
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Hans Bruch jr
703 İtibar
2 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 2
Her zaman: 10,762
