Ana içeriğe geç
Canon FS30 LCD Screen Replacement
Neye ihtiyacın var
    1. Canon FS30 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 1. Canon FS30 LCD Screen Replacement, LCD Screen: adım 1, 2 resimden 2.
      • Locate battery compartment cover. Turn the device over and locate the battery compartment cover.
      • Place a finger or thumb on the textured section of the battery compartment cover and push forward until you hear a click. Then lift the battery compartment cover.
      FixBot'a Sor
      Yorum Ekle
    2. Canon FS30 LCD Screen Replacement: adım 2, 2 resimden 1. Canon FS30 LCD Screen Replacement: adım 2, 2 resimden 2.
      • Locate the grey latch and move it aside. The battery is spring loaded and will pop up.
      • Remove the battery.
      FixBot'a Sor
      Yorum Ekle
    3. Canon FS30 LCD Screen Replacement: adım 3, 2 resimden 1. Canon FS30 LCD Screen Replacement: adım 3, 2 resimden 2.
      • Using the Phillips #000, remove the two screws on the LCD panel.
      • Using the Phillips #000, remove two more screws near the LCD panel swivel point.
      FixBot'a Sor
      Yorum Ekle
    4. Canon FS30 LCD Screen Replacement: adım 4, 2 resimden 1. Canon FS30 LCD Screen Replacement: adım 4, 2 resimden 2.
      • Use the plastic opening tool to remove the plastic cover from the LCD panel.
      FixBot'a Sor
      Yorum Ekle
    5. Canon FS30 LCD Screen Replacement: adım 5, 2 resimden 1. Canon FS30 LCD Screen Replacement: adım 5, 2 resimden 2.
      • Locate and remove two screws on the logic board.
      • Use the plastic opening tool to open the ZIF (zero insertion force) connector. The LCD ribbon should pop up.
      FixBot'a Sor
      Yorum Ekle
    6. Canon FS30 LCD Screen Replacement: adım 6, 2 resimden 1. Canon FS30 LCD Screen Replacement: adım 6, 2 resimden 2.
      • Locate the LCD screen underneath the logic board and slide it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Emanuel Keller
419 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S1-G4, Nance Spring 2017 USF Tampa, Team S1-G4, Nance Spring 2017 üyesi
USFT-NANCE-S17S1G4
4 Üyeler
15 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 34
Her zaman: 712
