Ana içeriğe geç
Canon ImageCLASS MF4350d Remove Right Side Paneling
Neye ihtiyacın var
  1. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Front Paneling: adım 1, 1 resimden 1.
    • Lift the printer lid up as shown in the photo.
  2. Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 2, 2 resimden 1. Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 2, 2 resimden 2.
    • Locate and remove the two 10mm side screws. There is one on each side.
  3. Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 3, 2 resimden 1. Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 3, 2 resimden 2.
    • Unhook the plastic panel from the printer starting from the top.
    • You may need to wiggle the panel a bit to loosen it.
    • To remove the bottom part of the paneling gently lay the printer on its back.
    • The scanner lid needs to be supported when moving the printer
  4. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 4, 3 resimden 1. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 4, 3 resimden 2. Canon ImageCLASS MF4350d Remove Right Side Paneling, Canon ImageCLASS MF4350d Remove Right Side Paneling: adım 4, 3 resimden 3.
    • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
    • Use a gentle back and forth motion to wiggle the hooks out.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Helena Yanez
458 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G1
5 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
Tore paper when removing jamed paper. A small piece of paper must still be in machine.
Louis Pike McCasland - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 21
Her zaman: 4,458
