Ana içeriğe geç
Canon ImageCLASS MF4350d Scanner Belt Replacement
Neye ihtiyacın var
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Disassembly: adım 1, 1 resimden 1.
      • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
      • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
      FixBot'a Sor
      Yorum Ekle
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 2, 3 resimden 1. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 2, 3 resimden 2. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 2, 3 resimden 3.
      • Locate the black and white hinges.
      • Gently lift out the black and white hinges.
      FixBot'a Sor
      Yorum Ekle
    3. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 3, 3 resimden 1. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 3, 3 resimden 2. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 3, 3 resimden 3.
      • Next, locate and remove the four 10mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 4, 1 resimden 1.
      • Gently, pry off the top plate, starting from the back of the printer.
      FixBot'a Sor
      Yorum Ekle
    5. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 5, 2 resimden 1. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 5, 2 resimden 2.
      • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
      FixBot'a Sor
      Yorum Ekle
    1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: adım 6, 2 resimden 1. Canon ImageCLASS MF4350d Scanner Belt Replacement, Scanner Belt: adım 6, 2 resimden 2.
      • Remove the black component by gently pulling it up from the black scanner belt
      FixBot'a Sor
      Yorum Ekle
    2. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 7, 2 resimden 1. Canon ImageCLASS MF4350d Scanner Belt Replacement: adım 7, 2 resimden 2.
      • Press down on the white release and force it in toward the spring as shown. While you do this, pull the scanner belt out of the track.
      • Take a new belt and put it in the same way that you took it out.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Tanner Papenfuss
584 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G1
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 7
Son 30 gün: 69
Her zaman: 3,687
