Ana içeriğe geç
Canon ImageCLASS MF4350d Scanner Disassembly
Neye ihtiyacın var
    1. Canon ImageCLASS MF4350d Scanner Disassembly, Scanner Disassembly: adım 1, 1 resimden 1.
      • If at any point you see glass that seems cracked or broken, handle with care. Broken glass is sharp and can cause serious damage.
      • Lift up the lid. Then be sure to examine the glass. If there are any cracks or broken fragments handle with extreme care.
      FixBot'a Sor
      Yorum Ekle
    2. Canon ImageCLASS MF4350d Scanner Disassembly: adım 2, 3 resimden 1. Canon ImageCLASS MF4350d Scanner Disassembly: adım 2, 3 resimden 2. Canon ImageCLASS MF4350d Scanner Disassembly: adım 2, 3 resimden 3.
      • Locate the black and white hinges.
      • Gently lift out the black and white hinges.
      FixBot'a Sor
      Yorum Ekle
    3. Canon ImageCLASS MF4350d Scanner Disassembly: adım 3, 3 resimden 1. Canon ImageCLASS MF4350d Scanner Disassembly: adım 3, 3 resimden 2. Canon ImageCLASS MF4350d Scanner Disassembly: adım 3, 3 resimden 3.
      • Next, locate and remove the four 10mm screws.
      FixBot'a Sor
      Yorum Ekle
    4. Canon ImageCLASS MF4350d Scanner Disassembly: adım 4, 1 resimden 1.
      • Gently, pry off the top plate, starting from the back of the printer.
      FixBot'a Sor
      Yorum Ekle
    5. Canon ImageCLASS MF4350d Scanner Disassembly: adım 5, 2 resimden 1. Canon ImageCLASS MF4350d Scanner Disassembly: adım 5, 2 resimden 2.
      • After you have taken off the plate, check to make sure that there is no broken glass. If there is broken glass handle it with gloves. Broken glass, if handled improperly, can cause physical injury.
      FixBot'a Sor
      Yorum Ekle
Sonuç
5 farklı kişi bu kılavuzu tamamladı.
Tanner Papenfuss
584 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G1
5 Üyeler
16 adet Kılavuz yazıldı
1Rehber Yorum
The paper tore and is now not visible. How do I remove the printer's components to access the paper deep in the machine? Is there a method to factory reset the machine? Can I somehow make the rollers rotate to attempt to pushing the paper out?
Kyle - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 12
Son 30 gün: 32
Her zaman: 5,965
