Ana içeriğe geç
Canon ImageCLASS MF4350d Transformer Replacement
Neye ihtiyacın var
    1. Canon ImageCLASS MF4350d Transformer Replacement, Front Paneling: adım 1, 1 resimden 1.
      • Lift the printer lid up as shown in the photo.
      FixBot'a Sor
      Yorum Ekle
    2. Canon ImageCLASS MF4350d Transformer Replacement: adım 2, 2 resimden 1. Canon ImageCLASS MF4350d Transformer Replacement: adım 2, 2 resimden 2.
      • Locate and remove the two 10mm side screws. There is one on each side.
      FixBot'a Sor
      Yorum Ekle
    3. Canon ImageCLASS MF4350d Transformer Replacement: adım 3, 2 resimden 1. Canon ImageCLASS MF4350d Transformer Replacement: adım 3, 2 resimden 2.
      • Unhook the plastic panel from the printer starting from the top.
      • You may need to wiggle the panel a bit to loosen it.
      • To remove the bottom part of the paneling gently lay the printer on its back.
      • The scanner lid needs to be supported when moving the printer
      FixBot'a Sor
      Yorum Ekle
    1. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: adım 4, 3 resimden 1. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: adım 4, 3 resimden 2. Canon ImageCLASS MF4350d Transformer Replacement, Right Side Paneling: adım 4, 3 resimden 3.
      • Gently unhook the right side paneling (as looking at the printer's front face) from the printer.
      • Use a gentle back and forth motion to wiggle the hooks out.
      FixBot'a Sor
      Yorum Ekle
    1. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: adım 5, 2 resimden 1. Canon ImageCLASS MF4350d Transformer Replacement, Transformer: adım 5, 2 resimden 2.
      • Locate the yellow wire connected to the metal box.
      • Carefully pull the yellow wire from the black connector.
      • Wires may detach completely from plug so tug very gently.
      FixBot'a Sor
      Yorum Ekle
    2. Canon ImageCLASS MF4350d Transformer Replacement: adım 6, 2 resimden 1. Canon ImageCLASS MF4350d Transformer Replacement: adım 6, 2 resimden 2.
      • Locate the spring.
      • Unhook the spring on the side of the metal box.
      FixBot'a Sor
      Yorum Ekle
    3. Canon ImageCLASS MF4350d Transformer Replacement: adım 7, 1 resimden 1.
      • Unscrew the 10mm screw attaching the metal plate to the printer.
      FixBot'a Sor
      Yorum Ekle
    4. Canon ImageCLASS MF4350d Transformer Replacement: adım 8, 1 resimden 1.
      • Lift the transformer out of the printer.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Helena Yanez
470 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 13-1, Forte Fall 2013 Cal Poly, Team 13-1, Forte Fall 2013 üyesi
CPSU-FORTE-F13S13G1
5 Üyeler
16 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 37
Her zaman: 3,502
