Ana içeriğe geç
Canon PIXMA MP620B Command Screen Replacement
Neye ihtiyacın var
    1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: adım 1, 1 resimden 1.
      • Open top lid of the printer to reveal the scanner
      FixBot'a Sor
      Yorum Ekle
    2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: adım 2, 2 resimden 1. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: adım 2, 2 resimden 2.
      • Insert the spudger tool into the top lid in between the blue and the black panels.
      • Use this tool to pry the two panels apart
      FixBot'a Sor
      Yorum Ekle
    3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: adım 3, 1 resimden 1.
      • After these two panels are separated, set the top panel to the side for now
      FixBot'a Sor
      Yorum Ekle
    4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: adım 4, 1 resimden 1.
      • Unplug the two wires shown at the right of the command screen
      FixBot'a Sor
      Yorum Ekle
    5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: adım 5, 1 resimden 1.
      • Unscrew the four screws shown to detach the command screen from the printer
      FixBot'a Sor
      Yorum Ekle
    6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: adım 6, 1 resimden 1.
      • Take the detached command screen off of the printer and replace.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Val Fedorikhin
860 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G21
4 Üyeler
10 adet Kılavuz yazıldı
2Kılavuz Yorumları
Ideas as to where to buy replacement screen assembly?
davepi49 - Yanıt Paylaş
same question
Jan de Ruiter - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 5
Son 30 gün: 29
Her zaman: 1,916
