Ana içeriğe geç
Canon PIXMA MP620B Command Screen Replacement
Neye ihtiyacın var
  1. Canon PIXMA MP620B Command Screen Replacement, Open Printer Lid: adım 1, 1 resimden 1.
    • Open top lid of the printer to reveal the scanner
  2. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: adım 2, 2 resimden 1. Canon PIXMA MP620B Command Screen Replacement, Pull apart the two large lid plates: adım 2, 2 resimden 2.
    • Insert the spudger tool into the top lid in between the blue and the black panels.
    • Use this tool to pry the two panels apart
  3. Canon PIXMA MP620B Command Screen Replacement, Take apart the two sections: adım 3, 1 resimden 1.
    • After these two panels are separated, set the top panel to the side for now
  4. Canon PIXMA MP620B Command Screen Replacement, Pull out wires leading to screen assembly: adım 4, 1 resimden 1.
    • Unplug the two wires shown at the right of the command screen
  5. Canon PIXMA MP620B Command Screen Replacement, Unscrew screen assembly: adım 5, 1 resimden 1.
    • Unscrew the four screws shown to detach the command screen from the printer
  6. Canon PIXMA MP620B Command Screen Replacement, Replace assembly: adım 6, 1 resimden 1.
    • Take the detached command screen off of the printer and replace.
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
Val Fedorikhin
860 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 6-21, Maness Fall 2014 Cal Poly, Team 6-21, Maness Fall 2014 üyesi
CPSU-MANESS-F14S6G21
4 Üyeler
10 adet Kılavuz yazıldı
2 Yorum
Ideas as to where to buy replacement screen assembly?
davepi49 - Yanıt
same question
Jan de Ruiter -
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 11
Her zaman: 1,313
