Ana içeriğe geç
Canon PIXMA iP3600 AC Adapter Replacement
  1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: adım 1, 2 resimden 1. Canon PIXMA iP3600 AC Adapter Replacement, AC Adapter: adım 1, 2 resimden 2.
    • It is very important to disconnect your printer from the outlet before attempting replacement. This ensures that there is no power reaching the AC adapter.
    • Remove power cord by disconnecting it from the AC Adapter.
  2. Canon PIXMA iP3600 AC Adapter Replacement: adım 2, 2 resimden 1. Canon PIXMA iP3600 AC Adapter Replacement: adım 2, 2 resimden 2.
    • Pinch upper and lower prongs, moving them away from the AC adapter.
  3. Canon PIXMA iP3600 AC Adapter Replacement: adım 3, 2 resimden 1. Canon PIXMA iP3600 AC Adapter Replacement: adım 3, 2 resimden 2.
    • The AC adapter will now be loose, and able to come away from the printer.
    • Grasp the AC adapter and pull it toward you to remove it.
  4. Canon PIXMA iP3600 AC Adapter Replacement: adım 4, 1 resimden 1.
    • Rotate the AC adapter toward you so that the blue cord, with white connector head, is facing you.
  5. Canon PIXMA iP3600 AC Adapter Replacement: adım 5, 3 resimden 1. Canon PIXMA iP3600 AC Adapter Replacement: adım 5, 3 resimden 2. Canon PIXMA iP3600 AC Adapter Replacement: adım 5, 3 resimden 3.
    • Grasp the white connector head that is attached to the end of the blue cord.
    • Disconnect the white connector head by gently pulling it away from the AC adapter.
    • You have successfully removed the AC adapter.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Caitlyn
1.202 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G3
3 Üyeler
8 adet Kılavuz yazıldı
3 Yorum
Does anybody know the pin-out for these power supplies?
James Rudee - Yanıt
WHERE CAN I BUY AC ADAPTER PIXMA GM 5220 PRINTER ? PLAESE !! my cell 678 899 1187, 770368 0409 w
vincent lieu - Yanıt
Well I’ve just taken the AC Adapter out - I’ll let you know if a the replacement works once I’ve purchased it - Which I am hesitant to buy in case that’s not the problem.
The printer is barely 2 years old and barely used, I shouldn’t be experiencing this problem of the printer not turning on.
Canon you need to get your act together if you would like to stay in business, I’m seeing a lot of comments on this problem over a range of different printer models - Mine is a Pixma iX6860.
rezidraft - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 9
Son 30 gün: 50
Her zaman: 5,106
