Ana içeriğe geç
Canon PIXMA iP3600 Printhead Replacement
    1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: adım 1, 1 resimden 1.
      • Press the power button to turn on the printer.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PIXMA iP3600 Printhead Replacement: adım 2, 1 resimden 1.
      • Pull down the front output tray cover.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PIXMA iP3600 Printhead Replacement: adım 3, 1 resimden 1.
      • Lift the printer lid.
      FixBot'a Sor
      Yorum Ekle
    4. Canon PIXMA iP3600 Printhead Replacement: adım 4, 1 resimden 1.
      • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
      FixBot'a Sor
      Yorum Ekle
    5. Canon PIXMA iP3600 Printhead Replacement: adım 5, 2 resimden 1. Canon PIXMA iP3600 Printhead Replacement: adım 5, 2 resimden 2.
      • Push in the white clip to release the ink cartridge from the printhead.
      • Lift the ink cartridge from the printhead.
      • Repeat this process for the remaining ink cartridges.
      • You have successfully removed all ink cartridges.
      FixBot'a Sor
      Yorum Ekle
    1. Canon PIXMA iP3600 Printhead Replacement, Printhead: adım 6, 1 resimden 1.
      • After removing all ink cartridges, lift the printhead lock lever.
      FixBot'a Sor
      Yorum Ekle
    2. Canon PIXMA iP3600 Printhead Replacement: adım 7, 1 resimden 1.
      • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
      FixBot'a Sor
      Yorum Ekle
    3. Canon PIXMA iP3600 Printhead Replacement: adım 8, 1 resimden 1.
      • You have successfully removed your printhead.
      FixBot'a Sor
      Yorum Ekle
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Caitlyn
1.223 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G3
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 14
Son 30 gün: 79
Her zaman: 9,508
