Ana içeriğe geç
Canon PIXMA iP3600 Printhead Replacement
  1. Canon PIXMA iP3600 Printhead Replacement, Ink Cartridges: adım 1, 1 resimden 1.
    • Press the power button to turn on the printer.
  2. Canon PIXMA iP3600 Printhead Replacement: adım 2, 1 resimden 1.
    • Pull down the front output tray cover.
  3. Canon PIXMA iP3600 Printhead Replacement: adım 3, 1 resimden 1.
    • Lift the printer lid.
  4. Canon PIXMA iP3600 Printhead Replacement: adım 4, 1 resimden 1.
    • Allow the belt, containing ink cartridges, to adjust and center so that the ink cartridges are visible.
  5. Canon PIXMA iP3600 Printhead Replacement: adım 5, 2 resimden 1. Canon PIXMA iP3600 Printhead Replacement: adım 5, 2 resimden 2.
    • Push in the white clip to release the ink cartridge from the printhead.
    • Lift the ink cartridge from the printhead.
    • Repeat this process for the remaining ink cartridges.
    • You have successfully removed all ink cartridges.
  6. Canon PIXMA iP3600 Printhead Replacement, Printhead: adım 6, 1 resimden 1.
    • After removing all ink cartridges, lift the printhead lock lever.
  7. Canon PIXMA iP3600 Printhead Replacement: adım 7, 1 resimden 1.
    • Pull up and lift out the black piece that previously held the ink cartridges. This is the printhead.
    Comment réparer la tête d'impression
    Mohamed el amine Baali - Yanıt
  8. Canon PIXMA iP3600 Printhead Replacement: adım 8, 1 resimden 1.
    • You have successfully removed your printhead.
Sonuç
6 farklı kişi bu kılavuzu tamamladı.
Caitlyn
1.202 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-3, Leahy Fall 2014 USF Tampa, Team 1-3, Leahy Fall 2014 üyesi
USFT-LEAHY-F14S1G3
3 Üyeler
8 adet Kılavuz yazıldı
1Rehber Yorum
fairly helpful, especially the photo's. but I need advice on how to clean the printhead before trying to replace it,
a1halber - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 82
Her zaman: 8,288
