Giriş
hello all,
today we wil take down the canon pixma ip4850.
This printer has the wel know problem : B200.
Most of the time this is a printhead problem.
you will see how you can replace the printhead and other parts. enjoy !
be carefull : its not an easy guide!
Neye ihtiyacın var
this printer has the well known B200 error.
we will take the printer apart.
first step : remove all the loose parts.
remove the panel at the back.
no we will remove the printhead and the cardridges.
To remove the printhead you have to plug in the printer again and open up te front panel (like you have to remove the cardridges).
to remove the printhead you have to pull the levar up (grey) , be carefull its very rough to pull it up.
remove the printhead, if you only replace the printhead the guide stops here. be carefull for the pcb board, if you only clean the printhead do it carefully. clean it with destilled water, but do not touch the PCB.
now we will remove the power supply.
you'll find clips to loose the power suply . On the picture (number 1) you see how you do it. you'll here the clicks.
pull the power supply out of the printer, and you will see the white and blue wires. you will see this wires later in the printer again.
4Kılavuz Yorumları
Fixing back the printer but the connector wires are damaged in the ends any better way to get the connectors working again?
unfortunately the Pixma MP printers and AIO are one of the most complicated to repair and undocumented in service guides printers in the world :(
Bonsoir,
Félicitations pour ce super tuto !
J'ai cherché sans succès sur le site son semblable pour une imprimante CANON IP 7250.
J'ai reçu un code B200 ; nettoyage tête d'impression et absorbeur d'encre.
J'avais rencontré ce problème il y a 2 ans et l'avais résolu en nettoyant la tête d'impression avec de l'eau distillée, mais cette fois c'est insuffisant. Il me faut passer à l'étape absorbeurs beaucoup plus lourde. Auriez-vous un tuto pour cette imprimante ou pourriez-vous m'indiquer le processus pour y accéder ?
NB : le démontage de la machine est fortement avancé.
Par avance, un grand merci, je ne voudrai pas rentrer dans le jeu de CANON consistant à forcer la vente au détriment d'une réparation.
Tous vos conseils seront bienvenus.
Bonne soirée. Dan
