Ana içeriğe geç
Canon Pixma MP480 Buttons Replacement
Neye ihtiyacın var
  1. Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: adım 1, 2 resimden 1. Canon Pixma MP480 Buttons Replacement, Rear and Side Panel: adım 1, 2 resimden 2.
    • Remove the two 7.9 mm screws using a Phillips #1 screwdriver.
  2. Canon Pixma MP480 Buttons Replacement: adım 2, 1 resimden 1.
    • Lift up the back cover to remove it.
    • You may need to lift firmly as it requires quite a bit of force.
  3. Canon Pixma MP480 Buttons Replacement: adım 3, 1 resimden 1.
    • Open the front tray.
  4. Canon Pixma MP480 Buttons Replacement: adım 4, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 4, 2 resimden 2.
    • Open the scanner compartment.
    • Make sure the blue lever locks into place to keep the compartment open.
  5. Canon Pixma MP480 Buttons Replacement: adım 5, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 5, 2 resimden 2.
    • Remove the blue lever from its slot by pushing it back and twisting clockwise.
    • Close the scanner compartment and cover.
  6. Canon Pixma MP480 Buttons Replacement: adım 6, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 6, 2 resimden 2.
    • Pry open the side cover with the plastic opening tool.
  7. Canon Pixma MP480 Buttons Replacement: adım 7, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 7, 2 resimden 2.
    • Flip the printer over so that the bottom of the printer is facing you.
    • Use the plastic opening tool to remove the corner of the side panel from the plastic pin.
  8. Canon Pixma MP480 Buttons Replacement: adım 8, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 8, 2 resimden 2.
    • Use the plastic opening tool to loosen the side panel from the bottom of the printer.
  9. Canon Pixma MP480 Buttons Replacement, LCD: adım 9, 2 resimden 1. Canon Pixma MP480 Buttons Replacement, LCD: adım 9, 2 resimden 2.
    • Using the plastic opening tool, pry off the top cover of the LCD assembly.
    • Pry around the front and side edges for the easiest removal.
  10. Canon Pixma MP480 Buttons Replacement: adım 10, 1 resimden 1.
    • After removing the top cover of the LCD assembly, remove the LCD using the plastic opening tool.
  11. Canon Pixma MP480 Buttons Replacement: adım 11, 1 resimden 1.
    • Gently pull the ribbon cable to remove the LCD completely.
  12. Canon Pixma MP480 Buttons Replacement, Buttons: adım 12, 1 resimden 1.
    • Locate the buttons on the top of the printer.
  13. Canon Pixma MP480 Buttons Replacement: adım 13, 1 resimden 1.
    • Using the plastic opening tool, gently pry under the button cover to remove it from its fixture.
  14. Canon Pixma MP480 Buttons Replacement: adım 14, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 14, 2 resimden 2.
    • Remove the five 7.7 mm screws using a Phillips #1 screwdriver.
  15. Canon Pixma MP480 Buttons Replacement: adım 15, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 15, 2 resimden 2.
    • Using the plastic opening tool, gently pry around the cover behind the LCD screen to remove it from its fixture.
  16. Canon Pixma MP480 Buttons Replacement: adım 16, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 16, 2 resimden 2.
    • Remove the two 7.8 mm screws using a Phillips #1 screwdriver.
  17. Canon Pixma MP480 Buttons Replacement: adım 17, 1 resimden 1.
    • Gently pull the LCD screen up to remove it from its fixture.
  18. Canon Pixma MP480 Buttons Replacement: adım 18, 1 resimden 1.
    • Use the plastic opening tool to pry off the plastic button assembly.
  19. Canon Pixma MP480 Buttons Replacement: adım 19, 1 resimden 1.
    • Gently pull the plastic button assembly up to remove it.
    • The plastic button assembly has a ribbon cable connected on the bottom, so be careful pulling it.
  20. Canon Pixma MP480 Buttons Replacement: adım 20, 1 resimden 1.
    • Remove the ribbon cable connected to the backside of the plastic button assembly.
  21. Canon Pixma MP480 Buttons Replacement: adım 21, 2 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 21, 2 resimden 2.
    • Remove the seven 8.7 mm screws using the Phillips #1 screwdriver.
  22. Canon Pixma MP480 Buttons Replacement: adım 22, 3 resimden 1. Canon Pixma MP480 Buttons Replacement: adım 22, 3 resimden 2. Canon Pixma MP480 Buttons Replacement: adım 22, 3 resimden 3.
    • Locate the spring that holds the PCB in place on the bottom left of the plastic button assembly.
    • Gently lift the spring and pull the board out of its plastic button assembly.
  23. Canon Pixma MP480 Buttons Replacement: adım 23, 1 resimden 1.
    • Remove the buttons from the plastic button assembly.
Sonuç
Khutug Dorjsuren
114 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 19-41, Regan Winter 2013 Cal Poly, Team 19-41, Regan Winter 2013 üyesi
CPSU-REGAN-W13S19G41
4 Üyeler
6 adet Kılavuz yazıldı
0 Guide Comments
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 12
Her zaman: 1,750
