Giriş
Use this guide to remove and replace a dysfunctional LCD display screen of a Canon PowerShot A1000 IS.
Aletler
Hiçbir alete gerek yok.
Parçalar
Hiçbir parçaya gerek yok.
  1. Transfer screws to a safe place upon removal. The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment. The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
    • Transfer screws to a safe place upon removal.
    • The case is held together with two types of screws: fine thread screws that attach the case to the metal parts below, and coarse thread screws that attach the case to the plastic battery compartment.
  2. Remove the two coarse thread screws on the side of the device, to the left of the camera lens. Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
    • Remove the two coarse thread screws on the side of the device, to the left of the camera lens.
  3. Remove the two fine thread screws on the side of the device, to the right  of the camera lens. Remove the two fine thread screws on the side of the device, to the right  of the camera lens.
    • Remove the two fine thread screws on the side of the device, to the right of the camera lens.
  4. Remove the two coarse thread screws and the single fine thread screw from bottom the camera. Remove the two coarse thread screws and the single fine thread screw from bottom the camera. Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
    • Remove the two coarse thread screws and the single fine thread screw from bottom the camera.
  5. Remove the one coarse thread screw underneath the battery cover. Remove the one coarse thread screw underneath the battery cover.
    • Remove the one coarse thread screw underneath the battery cover.
  6. Pro Tech Toolkit içeren veya $100tüm siparişlerde ücretsiz kargo!
    Mağazamıza Göz Atın
  7. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell. Gently pry apart the two covers starting from the bottom.  When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover,  to release the three catches that secure the shell.
    • Gently pry apart the two covers starting from the bottom. When there is a 1/4" gap, run your finger gently along the the top of the camera, on the back cover, to release the three catches that secure the shell.
  8. Gently remove both sides of the casing. Gently remove both sides of the casing.
    • Gently remove both sides of the casing.
  9. When replacing the cover, remove the AV/USB rubber cover for easier reconstruction. Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
    • When replacing the cover, remove the AV/USB rubber cover for easier reconstruction.
    • Replace the front cover first leaving a small gap on the left hand side of the device for easy reattachment of the back cover.
    • Reattach the back cover by aligning it with the front cover and snapping the latches into place. Secure with screws in any order.
  10. Insert wisdom here. Insert wisdom here. Insert wisdom here.
    • Insert wisdom here.
  11. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  12. Insert wisdom here. Insert wisdom here.
  13. Insert wisdom here. Insert wisdom here.
  14. Insert wisdom here. Insert wisdom here. Insert wisdom here.
  15. Insert wisdom here. Insert wisdom here. Insert wisdom here.
Sonuç
3 farklı kişi bu kılavuzu tamamladı.
Biff Wheeler
762 İtibar
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 Gün: 1
Son 30 Gün: 3
Her zaman: 1,046
