Ana içeriğe geç
Canon PowerShot A2200 Back Cover Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2200 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Back Cover Replacement: adım 2, 1 resimden 1.
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Back Cover Replacement: adım 3, 1 resimden 1.
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Back Cover Replacement: adım 4, 3 resimden 1. Canon PowerShot A2200 Back Cover Replacement: adım 4, 3 resimden 2. Canon PowerShot A2200 Back Cover Replacement: adım 4, 3 resimden 3.
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Back Cover Replacement: adım 5, 3 resimden 1. Canon PowerShot A2200 Back Cover Replacement: adım 5, 3 resimden 2. Canon PowerShot A2200 Back Cover Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
Sonuç
Jessica Huebschman
140 İtibar
1 Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G5
4 Üyeler
11 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 3
Son 30 gün: 17
Her zaman: 928
