Ana içeriğe geç
Canon PowerShot A2200 Button Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  2. Canon PowerShot A2200 Button Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  3. Canon PowerShot A2200 Button Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
    FixBot'a Sor
    Yorum Ekle
  4. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 1. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 2. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 3.
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
    FixBot'a Sor
    Yorum Ekle
  5. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 1. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 2. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
    FixBot'a Sor
    Yorum Ekle
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: adım 6, 2 resimden 1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: adım 6, 2 resimden 2.
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
    FixBot'a Sor
    Yorum Ekle
  7. Canon PowerShot A2200 Button Assembly Replacement: adım 7, 1 resimden 1.
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Gee
983 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G5
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 4
Son 30 gün: 32
Her zaman: 1,084
