Ana içeriğe geç
Canon PowerShot A2200 Button Assembly Replacement
Neye ihtiyacın var
  1. Canon PowerShot A2200 Button Assembly Replacement, Back Cover: adım 1, 1 resimden 1.
    • First, remove the batteries and memory card.
    • Remove the 5.0 mm black screw with a Phillips #00 screwdriver.
    • Remove the 5.0 mm silver screw with a Phillips #00 screwdriver.
  2. Canon PowerShot A2200 Button Assembly Replacement: adım 2, 1 resimden 1.
    • Remove the 5.0 mm black screw on the right with a Phillips #00 screwdriver.
  3. Canon PowerShot A2200 Button Assembly Replacement: adım 3, 1 resimden 1.
    • Remove the 5.0 mm screw on the left with a Phillips #00 screwdriver.
  4. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 1. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 2. Canon PowerShot A2200 Button Assembly Replacement: adım 4, 3 resimden 3.
    • Begin taking off the back cover with a plastic opening tool.
    • Begin by wedging the plastic opening tool behind the bottom left corner of the LCD screen as shown.
    • Slide the plastic opening tool to the right, along the mating edge, to pry off the back cover.
    • Continue taking off the back cover along the left side of the camera as seen in the third picture.
  5. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 1. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 2. Canon PowerShot A2200 Button Assembly Replacement: adım 5, 3 resimden 3.
    • Use the plastic opening tool to separate the top section of the back cover from the frame.
    • Once there is enough separation between the back cover and the frame, remove the back cover for replacement.
  6. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: adım 6, 2 resimden 1. Canon PowerShot A2200 Button Assembly Replacement, Button Assembly: adım 6, 2 resimden 2.
    • Remove the internal 4.4mm screw with a Phillips 00 screwdriver.
    • Make sure you're removing the screw circled in red, not the screw crossed out in orange.
  7. Canon PowerShot A2200 Button Assembly Replacement: adım 7, 1 resimden 1.
    • Gently lift of the buttons for replacement. They should come off without excessive force.
    • If the buttons do not lift off easily, you may have unscrewed the wrong screw. Revert to previous step.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Benjamin Gee
983 İtibar
5 adet Kılavuz yazıldı
Ekip
Baylor, Team 4-5, Williams Spring 2015 Baylor, Team 4-5, Williams Spring 2015 üyesi
BU-WILLIAMS-S15S4G5
4 Üyeler
13 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 7
Her zaman: 869
